Here is the stock wiring diagram. it's pretty similar for most old hondas.
Here is how you modify your machine so that you can see at night haha....
You will need a regulator/rectifier, A CAPACITOR (or battery) around 12v and somewhere around 2500-3500 microfarads should work, and obviously your LED headlight.
So some theory first,
Your trike runs on ac current, as do most old bikes and atvs. That means that the voltage your machine produces goes from + to - voltage many times a second.
You can hook up your LED headlight to your existing wiring, and it will likely work, For a short while.... But not for very long.
First you need to rectify the sine wave (make all of the negative voltage positive) with a regulator/recitifer
You will also need to unground your stator. This is accomplished by taking off your side case, removing the wire that grounds the stator to the case, and soldering a wire to that lead. I don't have any good pictures of that step so you will have to do a search.
K, a lot of people forget about or ignore this next step. YOU NEED A CAPACITOR OR BATTERY IN YOUR SYSTEM! If you dont get rid of that ripple effect (the 0 to positive voltage wave) you will burn up your led! (ask me how I know haha...) The capacitor will give you a consistent positive voltage. Which will make your LED light happy. I prefer a capacitor because it is small and you have no real need for a battery on a kick start or pull start trike haha...
Other than that, if you can't figure out how to read the diagram you should probably not try to tackle this project haha... but in this diagram i actually eliminate the ac system, but you don't have to do that. you can tee off of the ac system to run your brake light. But it's probably easier to just convert your whole system to dc, and it will all still work fine. You also will not need your high-low beam, unless you do something fancy with two lights. Pretty simple, and awesome results
