Results 1 to 12 of 12
Thread: ATC 110 chain problem
    1985BigRed250ES's Avatar
    1985BigRed250ES is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Rison, Arkansas, United States
    397
    I put the chain on my 110 today the chain as far as I can tell fits on the front sprocket but I cannot get it to fit the rear sprocket. The rear sprocket is a 49 tooth, not sure what the front one is but I believe I got it from bobbyjim here on the forums and he said it will fit the 110. The chain is a 428H. what am I missing here? any help would be greatly appreciated.
    Jordan
    1985 Honda BigRed 250ES
    runs good all original
    Restoration in progress:
    1980 Honda ATC 110
    1985 Honda ATC 250SX
    1982 Honda 200ES BigRed
    1984 Honda 200S
    1984 Honda 200S parts bike
    1985 Honda ATC 110
    1983 Honda ATC 110 parts bike, runs but smokes
    Feedback link: http://www.3wheelerworldforums.com/s...ad.php?t=95258
    397
    double thread, sorry mods, admins please delete.
    1980 Honda ATC 110
    1984 Honda 200S
    1985 Honda ATC 110
    Mar 2009
    Utah
    203
    Will it just not fit or can you not get it on?
    3 wheelers:
    '85 ATC 110 (its my first restoration!!)
    Saving up for a 250r later this year!
    397
    it will not fit the rear sprocket. I had to "roll the chain on" like you would have to on a bicycle and it sits on top of the teeth on the rear sprocket instead of in the valleys between the teeth.
    1980 Honda ATC 110
    1984 Honda 200S
    1985 Honda ATC 110
    Monroe MI
    5,787
    Quote Originally Posted by 1985BigRed250ES View Post
    You can delete the post yourself, click edit.
    Tionesta, PA
    5,744
    Sounds to me like either you have an extremely worn out rear sprocket - or it is plain and simple the wrong sprocket. My guess is that it is badly worn.
    Is it hooked?
    397
    Its a new sprocket, I used it along with the axle and bearing/axle carrier out of my old 1981 110. the sprocket was just replaced two years ago but has maybe 50 miles on it.
    1980 Honda ATC 110
    1984 Honda 200S
    1985 Honda ATC 110
    Feb 2009
    michigan
    2,387
    chain problem
    post a pic and all your questions will be answered by the gods
    1985 ATC 250R
    . Team Red Trike
    397
    didnt the 79-81 atc 110 have a 49t rear sprocket? and 82-85 had a 50t right?
    1980 Honda ATC 110
    1984 Honda 200S
    1985 Honda ATC 110
    397
    the chain, I know fits on the front sprocket, when I put it in gear and give it some gas, the chain does not catch on the rear sprocket, just kinda slips on top of it and it will not stay in the "valleys" on the sprocket even when tight. The sprocket is about two-four years old but only has about 50 miles or so on it. The sprocket is not worn, just dont know what I am missing. It has the #428H chain on it, it is a heavy duty chain could that be the problem?
    1980 Honda ATC 110
    1984 Honda 200S
    1985 Honda ATC 110
    Tionesta, PA
    5,744
    Do you have an old chain from this machine? If so lay it on the sprocket and see if it fits.
    Sounds like the wrong sprocket now.
    397
    I tried an old chain and it worked! the chain is kinda loose (stretched) and I will replace it tomorrow. the old chain is a 428H. the "new" one I had is too short I guess, because the "old" chain that is stretched, worked just fine. thanks for the help guys!!
    1980 Honda ATC 110
    1984 Honda 200S
    1985 Honda ATC 110
