Results 1 to 15 of 25
Thread: Help! Tri-Z guys...
    Racerguy381's Avatar
    Racerguy381 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2009
    Puyallup, WA
    265
    Help! Tri-Z guys...
    Well Im still having problems if anyone has a CDI box I need one. The stator didnt fix the problem and Im still stumped on anything else.
    So I have ran into a brick wall... I have been up and down with the jetting but it seems to have the same senario. Runs but craps out on top. My questions are if you have the same set up with a 38mm round slide are you still running the fuel pump and what needle seat# are you using. Next is who has a manual for an 85 Z that has the test specs for the stator volt regulator and coil. Any info is better than none considering I work at a Yamaha shop an we dont even have a manual that far back. Thanks guys
    Trikes
    1985 Tri-Z 250 Piped ported and PV'd
    1985 ATC 250R trail destroyer!
    1984 ATC 70 rebuilding
    1982 ATC 70 stut wheeler drag bar an cooler rack equipped
    1973 ATC 70 searching for parts...
    Bikes
    2006 KLX110 BBR160 Super R head ported BBR Super Pro rear swingarm ect...
    1988 KX500 The Beast!
    1986 KX540 In search of parts!!! Help if you have some
    1982 CR480 Unlimited Evo Racer
    1982 CR125 Unlimited Evo Racer
    1982 YZ100 cheater bike...
    1981 KX250 Unlimited money pit Evo Racer
    Southern MN
    1,875
    Do a search near the top right of your screen for REPAIR MANUALS. I know for a fact there is one for an 85 tri z, because I just looked at it yesterday. Good luck.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Monroe MI
    5,787
    Jan 2005
    RI
    2,530
    As far as your fuel pump question, try it with a full tank of fuel and see if that helps.
    Rebuild kits for the pump are CHEAP and its easy to do. Its a great piece of mind for 20 bucks.
    As far as you needle and seat question, id be more inclined to mess with main jets first, then once you get it close and its still not perfect, mess with the needle and the different tapers and such.
    Just do once change at a time and write down everything you try.
    Here are your specs:
    CDI Magneto Source Coil: Black to Brown Wire 315 ohms +-10%
    CDI Magneto Pickup Coil: White/Red to Black 10.7 ohms +- 10&
    Primary Coil Resistance : 0.79 ohms +- 10%
    Secondary Coil Resistance : 5.9k ohms +- 10%
    There wasnt anything about the voltage regulator in there, but all that does is keep your lights from blowing, so if they arent getting purple and blinding, you should be ok there.
    Tri-z's are somewhat known to rattle stuff loose. I had a z that ran like crap because the 2 bolts (that someone didnt loctite...me) that hold the stator plate on the case loosened up and the trike still ran but didnt have the right revs and i finally lost spark when it came totally loose and was eaten by the flywheel.
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Mar 2009
    Puyallup, WA
    265
    Thanks DeePa, I have been up down and even sideways with the jets... lol I have already rebuilt the fuel pump so I know its good. Think I will check the electical next just to be sure Im not chasing my tail for no good reason with the fuel issue. It is possible though cause if I pinn it on a bumpy whooped out road it seems to get better an want to rev.... which makes me think fuel... you see.... ya its just irritating me now. Thanks again
    Trikes
    Bikes
    Phoenix, AZ.
    6,719
    Make sure the float is adjusted right. It might be low which wouldn't cause a problem at low speed but the more throttle you're giving it, the lower the fuel level in the bowl will get. If it's too low it can definitely cause a similar symptom.
    Mar 2009
    Puyallup, WA
    265
    Ok so Im pretty sure gus not the carb now. I had a39mm air striker off a CR so I threw it on to try it. Same problem cuts out on top but runs great bottom to top. I even checked the stator test specs all passed. All the fuel lines and tank return lines checked out as well... So it could be stator still just a bad winding or CDI box is all I can think of now. Anyone know whats more common on these?
    Trikes
    Bikes
    na
    5,702
    Mine was doing something very similar to yours.
    Especially if the trike got wet.
    I had spare parts, so First I unpluged the on off switch and ran it. No help.I saw one Z a friend had busting up on the top,and a piece of steel would rattle in the switch and create a slight ground.They will run with the swictch unplugged, they just wont shut off.
    Then I tried a different coil, no help.
    Then a cdi box.No help.
    Finally, I threw a stator in it.
    Fixed it.
    I did the stator last cuz it took more work to change..LOL
    I would say coils are more common.They crack at the housing and arch to the frame.
    But it sounds as though it may be a stator.They can test good with resistance, but put out weak voltage under high RPM, that you could only find with a ocsillascope.
    Dumb question, but you have tried a new plug right?
    Proudly NOT a member of
    "Team on the Teat"
    check the orange wire where it comes out of the coil.. they like to crack there and jump spark there
    Mar 2009
    Puyallup, WA
    265
    Ok so who has a good stator or source coil? and how much. I have a friend checking to see if he has somthing that will work off a IT250 not sure if he does yet though.
    Trikes
    Bikes
    Jul 2008
    reno,nv
    18
    Talking tri z help
    im just joining the topic but i just built a tri z with a powervalve motor. craps out on top , 1st check to make sure your power valve is opening all the way, second did you use the stock fuel pump?if so replace with the mikuni jet ski pump, its like 21.00 dollers. third put an inline spark tester in it and rev it up were it cuts out. if you see a drop in spark than go that way. if that is the problem hit me up. if you pay shipping ill send you the electrical parts. 4th crank seals will make it run weird not to mention in some casses crap out on top.....
    whats your plug look like..
    Mar 2009
    Puyallup, WA
    265
    I know its not crank seals cause I just replaced all the mains and seals when I did the PV swap. It is the stock pump but I put all new diaphrams and gaskets in it. The PV does open all the way I already checked that too. As far as the plug goes its never really changed much in color no matter what jets I throw at it. Right now it has a 40 pilot and a 310 main but still is dark brown on the verge of black... This is whats making me think its electrical cause it will fool you into thinking its bad jetting when its really loosing voltage at the plug at high RPM. Plus it does it worse under a load.
    Trikes
    Bikes
    Mar 2009
    Puyallup, WA
    265
    Noticed tonight that the pilot light checker is cut out of the harness. All the wires are there. Would not having it hooked up effect it in any way we have talked about. Next would be does anyone have one?
    Trikes
    Bikes
    na
    5,702
    Your Tri-z will run fine with out the checker bulb box plugged in.
    When you went thru the motor, did you set your stator plate at the middle of the adjustment slots?
    "Team on the Teat"
