Results 1 to 10 of 10
Thread: just aquired ytm 200
    PA
    5
    hello. i just aquired an 84 ytm 200 and am new to this fourm. it's in fairly decent shape and the owner said it ran good when he quit runing it. I cleaned the carb out and flused the tank and put new gas in, got it running for about 5 minutes. now i can't get it to run at all! please help!
    STL
    3,560
    Post some pics! Welcome to the board too. When you were running it for 5 minutes, did you just shut it off and now it wont start or did it die on its own?
    1985BigRed250ES's Avatar
    1985BigRed250ES is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Rison, Arkansas, United States
    397
    does it have spark? is the spark plug fouled? air filter clean? Check to make sure that it is getting gas flow to the carb.
    1985 Honda BigRed 250ES
    runs good all original
    Restoration in progress:
    1980 Honda ATC 110
    1985 Honda ATC 250SX
    1982 Honda 200ES BigRed
    1984 Honda 200S
    1984 Honda 200S parts bike
    1985 Honda ATC 110
    1983 Honda ATC 110 parts bike, runs but smokes
    Feedback link: http://www.3wheelerworldforums.com/s...ad.php?t=95258
    Monroe MI
    5,787
    PA
    5
    i'm working on pics. plug seems good, not fouled. i had the choke on and it ran for the few minutes when i figred it was ok to turn it off, thats when it shut off. good flow through the air filter. i'm planing to take the carb off and check it out and clean it again. one problem i have is my arm and shoulder are killing me! the starter is missing all the de-comp parts, makes it tough to start. and as far as pics, how do i post them? thanks!
    PA
    5
    plug is getting great spark
    PA
    5
    got it running some more, but will only run with the choke on. also backfires through the carb alot. any ideas?
    Lewiston, N.Y.
    1,477
    Sounds lean? Maybe you have something in the fuel line? Sounds like its not getting enough fuel.
    Masshole
    2,191
    Read this, you will have a better understanding of whats going on and how to fix it.
    http://www.3wheelerworldforums.com/s...ad.php?t=55086
    Monroe MI
    5,787
    Are you sure you cleaned the carb good enough? Read this post by DC and then clean it again, can't hurt any.
    http://www.3wheelerworldforums.com/s...ad.php?t=23819
