Results 1 to 9 of 9
Thread: Mystery Hoses Tri Moto 175
    Ontario Canada
    4
    Hello everybody, I am new to this forum. Last fall I bought a Tri Moto 175 and rebuilt it. It was missing the hoses that come off the little black plastic piece off the right side of the engine. I was wondering if anyone could look at their machine for me and tell me where they go. Thanks.
    Maryland
    3,077
    Those hoses are probably for the auto oil injector. Most people take the hoses off and empty or remove the oil bottle as they aren't the most reliable things in the world.
    Nov 2008
    Coon Rapids, MN
    956
    The smaller one goes to the right side of the carburetor and the bigger one runs to the oil tank, but if I was you I would just block it off and run premix.
    1982 Yamaha YT125 tri-moto - Boyesen power reeds, YT175 front suspension, Headlight guard.
    1982 Yamaha YT175 tri-moto - Running but ugly
    1984 Yamaha YT 60 tri-zinger - Boyesen power reeds
    My feedback.
    http://www.3wheelerworld.com/showthr...ght=old-yellow
    My album
    http://www.3wheelerworld.com/album.php?albumid=98
    Ontario Canada
    4
    I premixed just in case, but the oil injection seems to running fine. The hoses I am talking about are not the ones that come out from the oil injector pump cover area. This little piece on the engine case is further back near the front of the rear right wheel. There is 2 small hoses coming out of it, and yes, one is larger.
    Baltimore, MD
    6,088
    That is a collection point for unburnt oil vapors and such. You are suppose to clean that out periodiacally as all kinds of nasty stuff will gather in there and it will get quite gooey. Also make sure to clean it out when ever it becomes submerged in water in case water and mud gets in there.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Ontario Canada
    4
    Great so you know what I am talking about! Thats half the problem solved, now I just need to know where hoses connect to.
    Baltimore, MD
    6,088
    Officially from the Yamaha shop manual, you should have an overflow drain on your carb, that is where it runs into. Then you should have a vent line that runs from the "overflow tank" which is it's official name, up to the "open tube" which should be in the backbone of your trike. Does that help you?
    Nicholson 185s
    Ontario Canada
    4
    Yes, thank you very much. I just finished it up and took it for a ride. Never been on one before, it is a lot of fun. Now I have to adjust the clutch so I can wheelie!
    Monroe MI
    5,787
