Results 1 to 13 of 13
Thread: Trike not running right
    Winnipeg
    211
    I have a 1981 185..
    She doesnt run so well..
    It has no power in 3rd or 4th gear.. have to play with the throttle to get it running in those gears!
    1-2 seem good!
    Put a NEW carb on and still runs the same.
    Bottom end??
    Baltimore, MD
    6,088
    If the 81 had points, it could be old points. Once the spring on the points wears out or gets weak it lets the points float at higher rpms and your trike won't run right.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Monroe MI
    5,787
    Sep 2007
    100mi west of Chicago
    3,582
    What is the jetting in the new carb? Also maybe adjust the clutch.
    Rob
    Nov 2007
    N.Ireland
    119
    Yep, if you're having to play with the throttle it sounds like the clutch...
    '87 Honda CB550F Super Sport (Awaitin a restore..)
    '82 Honda 185s Wee Cracker
    '83 Honda 185s Stripped, ready for re-build...
    '85 Honda 70 Once he's off the quad...
    '85 Honda 200es In midst of re-build...
    '85 Honda 250r Runnin Sweet..
    '07 Honda 450fe 4WD workhorse
    '94 Suzuki LT50 Well, he has to start somewhere...
    If at first you don't succeed,
    SkyDivin ain't for you....
    Winnipeg
    211
    what do I need to do to adjust it?
    It goes into gear 1st and 2nd no problem.. but third is iffy and 4th... forget it.. bogging and running bad.. almost stalling
    Tionesta, PA
    5,743
    That is a carb problem for sure - have you had it off the bike and abart and cleaned it? I'd start there.
    Winnipeg
    211
    its brand spankin new.. the old one did the exact same thing!
    Apr 2006
    London Ontario, Canada
    1,197
    When you are in first or second, the bike runs good all the way threw the throttle range (from idle to right before you have to change gears)?
    Tapper
    R.I.P. Sandpuppie, you are greatly missed!
    May you rest in peace Jeswinehart, deeply missed, never forgotten....
    Feedback thread http://www.3wheelerworld.com/showthr...ight=tapper190
    Feb 2009
    michigan
    2,387
    running problem
    adjust the clutch,manual on this site.a screwdriver and wrench is all you need
    1985 ATC 250R
    . Team Red Trike
    Winnipeg
    211
    I took off the air box and now she goes into 3rd and 4th.. but she bogs JUST A LIL BIT... still a lil rough! BUT A HECK OF ALOT BETTER THAN BEFORE!
    and yes I cleaned the filter and box when I put the new carb on.. guess ill have to run it without the box.
    where do I find how to adjust the clutch??
    Monroe MI
    5,787
    From the manual
    Engine must be OFF
    Loosen the locknut
    Turn the adjusting screw one full turn clockwise.
    Slowly turn the adjusting screw counterclockwise until resistance is felt.
    Then turn the adjusting screw clockwise 1/4 turn and tighten the locknut.
    Winnipeg
    211
    i dont have a manual.. is there a link online.. I cant seem to find my year and model
