Results 1 to 15 of 15
Thread: 83 or 84 110 atc, troubles with rear end
    Ontario
    8
    Question 83 or 84 110 atc, troubles with rear end
    Hello, picked up this 110 atc, pretty much most of it came in a box. Anyways motor is all done up, frame is painted although I need to cut off and weld on a new handle and/or wheelie bar when I noticed the rear end .
    The question I do have though, is there an online guide to taking it apart? I'm betting my bearings are toast, whole axel rocks inside frame.
    Here's a video on youtube of it (HD version will be available shortly)
    http://www.youtube.com/watch?v=TD-He...e=channel_page
    I have some of the axel apart and have done some searching to find guide(found some info but not enuff to start sledging).
    Oh... one last question. Good online place to order whole stuff for rear end? Ie brake pads, bearings and... whatever else?
    Thanks in advance.
    Ivan
    Monroe MI
    5,787
    Ontario
    8
    awesome, thanks
    Feb 2009
    Wisconsin
    521
    looks like it needs bearings
    1985 Auto X lots of upgrades
    1982 Honda 185s 3inch wheel spacers, bassani exhaust
    2001 400ex
    1983 110
    Ontario
    8
    Wink
    Ummm... good suggestion where to buy? Just go to dealer or online better deal?
    Thanks in advance.
    Ivan.
    OHIO
    2,857
    got a whole rear carrier and axle if your stuff is wore out?? Looks like bearing will cure it. Also, make sure long bolts through carrier are tight?? Mine worked loose 2 times before lock tight man!! Good luck
    Monroe MI
    5,787
    Ontario
    8
    Wink
    Unfortunately no vin, or atleast I can't seem to find it.
    Had ordered bearings and seals for rear plus a set o shoes(hopefully another 30+ years before she needs to be redone. Front bearings should also be done but can do those any time and want to get her to run before I spend more money on it.
    I know I need to find a throttle thumb switch... not sure what else... had regreased steering bearings. Oh yea need to track down an exhaust... or perhaps an after market. Can't search right now but just curious is there an aftermarket to add a few more ponies? or part of a pony!?
    1985BigRed250ES's Avatar
    1985BigRed250ES is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Rison, Arkansas, United States
    397
    the vin number will be on the front of the frame where the forks mount, its on the tube that runs vertical. it will be on the left side of the frame.
    1985 Honda BigRed 250ES
    runs good all original
    Restoration in progress:
    1980 Honda ATC 110
    1985 Honda ATC 250SX
    1982 Honda 200ES BigRed
    1984 Honda 200S
    1984 Honda 200S parts bike
    1985 Honda ATC 110
    1983 Honda ATC 110 parts bike, runs but smokes
    Feedback link: http://www.3wheelerworldforums.com/s...ad.php?t=95258
    Ontario
    8
    Well there are 2 holes where im assuming the vin tag was...
    Monroe MI
    5,787
    Post some good pics of it. The 110 guru's might me able to tell you the year by looking at it.
    Grande Prairie, Alberta, Canada
    96
    Try a local bearing wholesaler. Most cities will have one. I just did all the wheel bearings on my 82 110 with better ( sealed ) bearings for a third the price that handa was going to charge. Not only that but honda's parts fiche actually had a typo on the front bearings and they were trying to sell me ones that won't fit.
    Ontario
    8
    Wink
    H2 that's crazy! Anyways it's the right year... my buddy is a mechanic with exact same three wheeler(only his is in mint condition! But it needs new rings and piston )
    Still waiting on bearings... will do em when it gets here otherwise will have axel sitting on floor o garage in a garage with not much room to begin with.
    Ontario
    8
    Angry
    ARggh.... $#@%, had checked serials, serial on the frame is a 1979. The engine serial didn't seem to match anything with the "S" in it, so I went for 79 points. Apparently the one piece I have doesn't match the 79.
    Is it possible to have the 79 points run on this motor? There is only one wire out from the points. It looks like there are 2 on the motor.
    Attached Thumbnails Attached Thumbnails IMG_4268.jpg   IMG_4270.jpg   IMG_4272.jpg   IMG_4273.jpg
    Ontario
    8
    Unhappy
    anybody?
