its repairable 100%, just because its weakend around the break means very little. it took ALOT of force behind that gear to do that in the firstplace. i dont see anything else normal breaking the case once its welded up. and i mean welded. not JB weld. i would not even think of buying a new case. a shop would maybe charge 10 bucks tops to fix that properly. its not bad to the point where i could even weld it. i just dont have the proper wire/tips to do so with my little welder. its obvious it wont look great. the case is pushed out, and it will most likely crack if you try to knock it back. id just get it filled and grind it down as nice as you can. and you will be 100% fine. unless the gear goes again it will probaly almost make it fully through next time.
I can feel your love for
s,and I know you are joking about the water-cooled trike comments, at least I hope you are.
