Thread: Dim Light bulb on ytm 200
    Oct 2008
    Manitoba
    4
    The headlight on my 83 ytm 200k is incredibly dim. What would cause this?
    Checked out all the coonections and they are good. Cleaned them all, no corrosion....Is this a stator problem? Or something else?
    Feb 2009
    Wisconsin
    521
    When you increase the rpms does it get brighter?
    1985 Auto X lots of upgrades
    1982 Honda 185s 3inch wheel spacers, bassani exhaust
    2001 400ex
    1983 110
    Monroe MI
    5,787
    Are you running the correct bulbs in both front and rear?
    Mar 2008
    South Georgia
    81
    yes make sure the bulbs are the correct wattage and then after that i would clean all of the grounds, even though you think they are good .1 ohm of resistance in a ground will do a lot.
