Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Thread: 1983 185s BRAKE PROBLEM
    greythorn3's Avatar
    greythorn3 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2007
    ALASKA
    302
    got my brakes and bearings in 10 minutes ago. will do the front when my wife gets home tonight so she can watch our baby.. cant wait to feel them front brakes work!
    might do the rears tomarrow since i have new rears and rear bearings too.
    1985 big red 250es working good. 1983 200e waiting for new crank and rod. 200x project looking needing everything.
    greythorn3's Avatar
    Aug 2007
    ALASKA
    302
    well got the bearings and the brakes in the front, man anyone know where to download a pdf manual for a 83 atc honda 185s???? if so please let me know where.. my brakes grab good, when i spin them, but i have to move the wheel again and they release slowly.. thinking maybe im missing a spring on the outside like my 200s has for the front brakes.. the cable is a little stiff though too.. i did soak the cable in oil.. it helped but isnt as free moving as a nice new one.. might have to order one.
    Ray
    greythorn3's Avatar
    Aug 2007
    ALASKA
    302
    nevermind i have the pdf already! although it doesnt show a exploded view of a 83 185s fromt drum brake hub assembly! anyone have a pic of what should be all on a 185s drum brake hub?
    Monroe MI
    5,787
    Mar 2007
    Texas
    5,045
    i have a factory honda service manual in my sig. there's a link to honda stuff. the 200s is the exact same rear brake as your 185s.
    ________________
    https://www.mikesatvfix.com
    greythorn3's Avatar
    Aug 2007
    ALASKA
    302
    thank you, perfect! looks like i got everything i need.. must be the sticky cable.. will soak again..
    I am working on the front brake system, and it seems different then my 200s's front brake, the 200s has a external spring on the arm.
    Ray
    Monroe MI
    5,787
    Make sure you clean the hole real good in the drum, where the cam goes though (so it operates freely).
    greythorn3's Avatar
    Aug 2007
    ALASKA
    302
    Quote Originally Posted by MonroeMike View Post
    i didnt clean that hole.. maybe i will pull it back apart and clean it, seems to move fairly easy though when i had the brake out
    Baltimore, MD
    6,088
    Take an old tire innertube and cut one by hand. You have to be a little more resourceful than that if you have a trike. You also might want to look into buying some cork gasket at your local auto store and cutting a cork gasket if you don't have any rubber handy. Also if you have your front end taken apart, make sure and clean up all your parts and lubricate them so the move smoothly. You might also need an o ring for your brake actuating shaft. Some trikes take the o ring and some don't. Try and get new springs for your brake shoes if they don't come in the kit, they will help your brake return and don't forget to lube your brake cable inside the housing. Who knows how long it's been since the last time it was lubed. Get on out and do some much needed maintenance on that trike.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
