Well I got the frame powder coated, shock spring, pegs, fender brackets, brake pedal and other stuff. I bought two engines out of PA that I found on craigslist for the build. I also had the front rim and hub powder coated black to match the rear ITP Baja black rims. The motor has a great crank and trans. I had the cylinder checked out at Brewer Cycles and honed with new a new piston and rings. I'm happy that I don't have to spend boat loads of money on motor work. I put a sweet G-Force axle + 4 inches for a Banshee from RMATV, Black Baja 8" rims with Fast Trekker 18x11x8's on the rear from EastCoastATV. They make the bike look sweet but I know they are not designed for the trail because of ground clearance. Oh I sand blasted the cylinder to show off the shine underneath. I'm trying to put this together in two weeks for a ride that me and ten friends are going on to Busco Beach in NC. The pipe is a Jemco with a DG silencer. I'll post other pics as I build this sweet ride. I'm also building a true 86 Tri-Z at the same time. I've been looking, saving, and piling parts over the last eight months for this build and the 86. I still need 2 kick starters and some yellow shrouds. Brrrraaapppp!
and how many z's you got ? four?? should share them
