Results 1 to 9 of 9
Thread: "rigged" big red 250es rear wheel spacer?
    rebel33382 is offline At The Back Of The Pack Arm chair racerFirst time rider
    New Orleans, LA
    201
    I put a pair of foreman 400 rims and mudbogs on the 250es, they look great and fit almost perfect, I need like a 1/8" of spacing for the muffler and for the frame on the left wheel. is there any quick solutions for this??
    1984 200ES first Shaft driven big red with reverse!
    85 Big Red 250ES with a rebuilt top end!
    Southern MN
    1,875
    If you were any good at welding or fabricating, I would say make up a set of wheel spacers that bolt to the stock hubs using longer bolts instead of studs to extend it a couple inches on each side. They make these, but I dont think you will find any for the big red bolt pattern rim or hub. Good luck!
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Oct 2007
    Minneapolis mn
    4,067
    New Orleans, LA
    201
    I am looking for a home made quick fix...any ideas???
    Monroe MI
    5,787
    Are those offset rims? If so, try turning them around. The valve stem will be on the inside though.
    Mar 2005
    overton, PA
    5,257
    or stick a 1/4 inch washer between the wheel and the hub
    Nov 2008
    ontario
    1,055
    would that weaken the studs though brapp?
    proud owner of a trx300ex quad and an 85 atc 70
    Sep 2007
    California, USA about 50 miles north of sacremento
    976
    Quote Originally Posted by brapp View Post
    Dang beat me to the post. I was going to say the same thing. Get longer grade 8 studs and you have extensions.
    I also did the wheel flip on my wifes quad. Gave it like a 2 1/2 inch extension..lol Them old polaris wheels sink way under the plastics, flip'em over and gain a few inches.
    I am going to go home and get some washer and bolt extensions for the new X!
    New Orleans, LA
    201
    so you are saying punh the factory studs out the hub and put some longer studs in with washers. where do you get longer studs from??
