Trying to adjust the valves on an 82 200m. I got the T mark lined up with the notch in the case. I do not feel any play in the rockerarms. even when i rotate it 180. Do I need to use a little more force? The rocker arm should be able to move up and down by hand? Then... where do i insert the feeler guage. Manual says between the rocker arm pad and the cam lobe. I cant see anything I would call a cam lobe at all. Just the rocker arm. Can anyone offer some tips here. Thanks
