Results 1 to 12 of 12
Thread: Adjust valves
    Apr 2009
    Parker, CO
    607
    Adjust valves
    Trying to adjust the valves on an 82 200m. I got the T mark lined up with the notch in the case. I do not feel any play in the rockerarms. even when i rotate it 180. Do I need to use a little more force? The rocker arm should be able to move up and down by hand? Then... where do i insert the feeler guage. Manual says between the rocker arm pad and the cam lobe. I cant see anything I would call a cam lobe at all. Just the rocker arm. Can anyone offer some tips here. Thanks
    Monroe MI
    5,787
    My manual says to insert the feeler gauge between the adjusting screw and the valve stem. 0.002 in. (0.05 mm) for both.
    Apr 2009
    Parker, CO
    607
    Hmm, does it have a picture?
    Does this diagram look correct? The parts labeld properly and what not:
    Im thinking its wrong. But thats the only place I can see to put a feeler. Thanks
    Your parts are labeled wrong mohadib.
    If you stick the feeler between the bottom of that flathead adjustment skrew and the top of the valve you should be fine.
    6,812
    Pics not correct . You see were the sloted screwdriver goes on the rocker arm adjustment screw ? The bottom of that were it touches the valve is were you place the feeler guage . Loosen the locknut when the motor it top dead center and make your adjustments .
    Monroe MI
    5,787
    The feeler gauge goes inbetween here.
    Oregon
    2,471
    YES..... you got it
    Apr 2009
    Parker, CO
    607
    Alright, thanks everyone! I finally got it. They are just right to at .002inch. At .003 it left really light scratches on the feeler, .002 slid in with resistance but no scratches and moved around pretty easy. The one on the intake side was pretty hard to get at! Thanks again!
    Oh, BTW Clymer manuals seem to be kind of crappy compared to other manuals you guys have given me. I'll not be buying one of theirs again!
    Monroe MI
    5,787
    Just a note, your better off a little loose, than too tight. Don't want to burn a valve.
    Mar 2007
    Texas
    5,045
    in my sig is a link to download a manual for that motor. same as a 200s for the top end and 200e and 200es and 200x top ends.
    ________________
    https://www.mikesatvfix.com
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    Make sure you have it at .003, mabey even between .003 and .004, leave em a tad loose....they will tighten up.
    TF 07,08,09,10,11,12,13,14!
    Aug 2004
    Ab Canada
    4,368
    http://www.3wheeler.org/dirtwheels/6...neupindex.html
    There is a Good little Write up on it,
    1985 Tri-Z-
