Results 1 to 15 of 29
Thread: No spark - 200e
    juggaloclownz18's Avatar
    juggaloclownz18 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    The woods of 315 - NY
    303
    No spark - 200e
    I just got done making new gaskets for the BR and put her all back together with no leaks, but now it has no spark.
    Took her all apart again and everything looks good, can someone tell me where i should start to look for issues?
    I really want to ride it, its been 3 weeks since i got it, and i have worked all the other issues out, this is the last one, and my thumb is itchin for the throttle ;-)
    85 ATC250r (been waiting way too long!!)
    Tusk Hand Guards
    DG full exhaust (want different one)
    TAG handlebars
    +4 LSR axcaliber axle, carrier, hubs
    FMF Carbon Fiber reeds,
    K&N Filter/air box lid removed
    Motion Pro Twist Throttle
    Pro Armor Tether switch
    Seal Savers - long version
    23" Dirt Devil front - 22" holeshots back
    Soon to be ported/polished (got the work setup on trade)
    Feb 2009
    Rome,NY
    1,046
    did you clean the fly wheel? with what you did you really shouldn't have lost spark? Make sure every thing is plugged in properly and also check your plug wire that is what happened to my auto x
    Feb 2009
    303
    Yeah, i did clean it off with a rag, no oil on it when i put it back together. Ill have to pick up a plug wire from somewhere, i just borrowed a multimeter to test some things, not sure how/where to start but ill start somewhere im getting really irritated because every time i fix one problem and want to ride, another one comes my way!
    Tusk Hand Guards
    TAG handlebars
    Monroe MI
    5,787
    Feb 2009
    Rome,NY
    1,046
    you know you ride three wheeler's when "im getting really irritated because every time i fix one problem and want to ride, another one comes my way!
    __________________" there was just a post on here about testing coils but if it ran and now it dosen't .....
    Feb 2009
    303
    hahaha yeah, i just got it 3 weeks ago and i have not had the chance to even ride it yet lol
    Im running down the the sled shed and getting a new plug wire, ill start there, then if its not that, i guess its the ole cigarette in the tank trick ;-)
    Tusk Hand Guards
    TAG handlebars
    Feb 2009
    303
    Well... Got a new plug wire and that was not the problem i guess, still no spark.... Looks like its time to test some things, Coil here i come you little booger LOL
    Tusk Hand Guards
    TAG handlebars
    Feb 2009
    303
    Well the manual shows what parts to check and it also shows how to check the continuity for the switches but what about testing the other things like the CDI, pulse generator, ignition coil etc etc....?
    Tusk Hand Guards
    TAG handlebars
    Feb 2009
    303
    EDIT*** There is continuity, for both positions on the stop switch, i guess i am to stupid to type LOL
    How can i bypass this to see if it will fire again without the stop switch?
    Tusk Hand Guards
    TAG handlebars
    Apr 2009
    Parker, CO
    607
    It had spark before you dissasmbeled it?
    Feb 2009
    303
    Yeah it had spark and ran fine, the only issue it had that made me tear it apart was an oil leak from a hole in the case, and bad gaskets, so i fixed those and put it back together and no spark.... however does the lack of proper continuity in the kill switch indicate its bad, or is that not my issue?
    EDIT*** Cannot type again :-)
    Tusk Hand Guards
    TAG handlebars
    Apr 2009
    Parker, CO
    607
    Hard to say offhand. I know lots of people read the diagrams wrong or test incorrectly. Then they wind up replacing all kinds of parts when they didnt need to. I think its unlikely your kill switch just died. I would look somewhere else. But, it could be it, who knows. I always start by checking for a good ground before anything. Good Luck.
    Feb 2009
    Rome,NY
    1,046
    all the kill switch does is ground so just unplug it for now
    Feb 2009
    303
    I unplugged it and still nothing... But it is showing continuity when i unplugged to test it (for both positions)... All the other tests came out fine so far, going to test the ignition coil next, i just put new plug wires and plug on lastnight...
    EDIT*** I typed the wrong thing, it HAS continuity in both the "on" and "off" positions...
    Tusk Hand Guards
    TAG handlebars
    Mar 2007
    Texas
    5,045
    then somethins shorted on the harness. you can get a complete replacement harness for liek $20 shipped off ebay. i picked up 2 of them.
    ________________
    https://www.mikesatvfix.com
