Results 1 to 15 of 15
Thread: My new motorcycle... well, 45 years old
    MA
    385
    Just registered it yesterday and rode it to work today.
    It's a 1964 Honda CT200, AKA 'Trail 90'. 2300 miles and all original!
    It's 90cc of pure power with 4 gears.
    I'm 190lbs and it pulls me to 50mph easy.
    I haven't detailed it yet. Needs a good cleaning and polishing.
    Just thought I'd post it up. I'm sure some of the older folks here will remember these
    Tionesta, PA
    5,747
    I love those old bikes. Looks like you got a nice one there. Good luck with it!
    Monroe MI
    5,787
    My friend had one of those, when I was a kid. I remember burning my leg on that pipe. Good times.
    Yours is in great shape.
    Aug 2002
    691
    nice! time to get you a 160cc chinese motor and bolt in it haha :P
    73 cr250m elsinore, 85 atc70, 85 250r flattracker, 87 250es bigred, 86 tecate, 2004 gas gas de300
    MA
    385
    Lifan does have a 12v 4-stroke 4-speed 125cc that bolts in.
    I wouldn't mind a China motor for offroad or a pocketbike... but for a motorcycle that gets regular use? Ehhhh... no thanks.
    topless is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2007
    Kansas
    160
    I've got 2, a 1970 that's being restored and a 1978 that's ridden almost daily. I had a 140cc in the '78 for over a 1000 miles then decided it was worth more stock. I bought the '70 cheap and if it won't run, it's getting the 140cc.
    I love my cargo box.
    Sweet little machine there
    Whats that other sprocket for?? Looks like a "trials" bike type sprocket
    I wonder how many of those are bombing around in China, those guys drive like nutz over there :lol
    Aug 2004
    Ab Canada
    4,368
    Nice, One of the most indestructible bikes out there, i had a 78, rode the pegs and everything else off it...Could kick start it by hand and it ran like a champ..
    1985 Tri-Z-
    Jun 2003
    Anchorage/Homer, Alaska
    480
    The two sprockets on the back; one is for high range, the other for low range! Slip the chain to the other sprocket for a quick ratio change. IIRC they only had this setup in the first year of Trail 90's till they changed to a high/low lever. (much like the ones on the 200es or 125m)
    Very nice looking machine!
    Mine needs some work... too many projects and being deployed don't help!
    1985 ATC 250ES, Big Red
    1984 ATC 125M's, 1.5 of 'em
    1983 ATC 110, BLUE!
    1974 ATC 70 Pink?
    Feb 2009
    michigan
    2,387
    old honda
    very cool old bike, thanks for sharing
    1985 ATC 250R
    . Team Red Trike
    Sep 2007
    oregon
    2,292
    pssh gpx 160 motor like the one edog had on that atc 90 would be sick...
    Dec 2007
    Kansas
    160
    The high/low range is exactly like an ATC90/110. They are surprising what they'll climb in low range and with an auto clutch you can walk it out of places that would be much harder with a hand clutch.
    Here's what it looked like with the 140cc, It would run 60mph and was pretty quick.
    Mar 2008
    Tug Hill
    1,282
    wouldnt you need a longer chain to use the bigger sprocket? and does the front sprocket slide over or is the alignment off from one to the other??
    HONDALUVR's Avatar
    HONDALUVR is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2007
    ARKANSAS
    250
    I have the one with the 4 hi gears and 4 low gears ... nice ride ... like an atc110 on two wheels ...
    IT'S A TEAM GREEN THANG !!!
    Dec 2007
    Kansas
    160
    Quote Originally Posted by lndy650 View Post
    They have a little box that carries extra links, 8- I think to run the big sprocket. The later ones have the high/low range that you flip a lever on the tranny case like the ATC 110.
