Page 1 of 7 1 2 3 ... LastLast
Results 1 to 15 of 105
Thread: 200x head on a 200s PICS
    litebulblsc's Avatar
    litebulblsc is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2009
    LaSalle, MI
    313
    I have been thinking of putting a 200x head and valvetrain on my 1985 200s. It should make a little more power. Plus it would take care of a few problems my trike has. How difficult would this be and is it just an easy swap? Does the 200x head have a smaller combustion chamber resulting in higher compression? How hard are these timing chains to do, I have did them on cars before but never on a cycle. What year 200x head would work? Would it matter if it a one or two peice?
    Answers to any of these questions would help.
    Thanks in advance,
    Josh
    Southern MN
    1,875
    The 200x head from the years of 83-85. It is a very easy swap to do, and the timing is easy enough to figure out. It should make a little more power, especially if you use the X carb and cam. Do you plan on using the 200x cam also? All the parts are a direct swap. Make sure you use a new head gasket, and dont use too much sealer on the rocker arm cover. Review a service manual if needed. Good luck!
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    May 2009
    LaSalle, MI
    313
    Ya I plan to use the cam and carb if I can find one cheap enough. Right now it looks like the head and cam I might be able to get fro 20 dollars.
    Feb 2009
    Rome,NY
    1,046
    the valve size is the same .... how does it make any more power? Head volume also looks the same (the x had a flat top piston to get a higher compression number)
    May 2009
    LaSalle, MI
    313
    Different cam
    Santa Barbara, California
    1,161
    I have a used head and rocker head cover from my '85 200x for sale, probably needs a valve job but other then that it seems fine.
    1985 Honda 200x
    May 2009
    LaSalle, MI
    313
    How much shipped to 48145?
    1,161
    Quote Originally Posted by litebulblsc View Post
    $45?
    1985 Honda 200x
    May 2009
    LaSalle, MI
    313
    I got a line on a cheaper one right now but if that doesn't work out I will keep you in mind. Do you have a cam you could throw in too?
    1,161
    I don't but the $45 was obo, let me know I am open to offers.
    1985 Honda 200x
    May 2009
    LaSalle, MI
    313
    Sent pm to ya
    Aug 2002
    Creswell, OR
    889
    The changes are in the cam and pistons. Not in the heads.. Rockers changed for compatibility to the decompression.
    www.3wheeler.org
    * * * Nothing scares me more than someone who knows, with certainty, what is best for me * * *
    Monroe MI
    5,787
    Different cam
    Same part number for the 200s and the 200x?
    CAMSHAFT 14101-965-000
    May 2009
    LaSalle, MI
    313
    You know they have the same part number or are you trying to find out if they do?
    Monroe MI
    5,787
    I looked them both up. Just wondering how they could be different, with the same part number.
