As BG said IF---IF you current "primary master" drive is set for cable select(jumper) then you will have to make sure that is the last drive on the cable. If not set for cable select, then you can just set your drive that your trying to get your info off of for a "slave" and plug it into any available connector that your HDD is plugged into. Now depending on which operating system your using , on reboot it may ask you to set up the "new" old drive. Good luck extracting all your old qorn pics
1985 Honda 125M (My first Trike--Still have it)
1986 Honda 250SX
1981 Honda 110
1982 Honda 110
1986 Yamaha YFM80 (Sons quad)
Past rides: 1983, 1984 200X, 3--1985 Kawasaki T-3
1987 CR-80, 70's vintage XR75, RM 370
