Results 1 to 8 of 8
Thread: honda 200e front sprocket
    Nov 2004
    Eastern Iowa
    12
    Thumbs down honda 200e front sprocket
    I need to replace the front sprocket on my 200e and I have the pull starter, sub transmission, and all the bolts out as well as the seals for the pull start flange and the neutral indicator but the cover that the electric start bolts to still will not come off. Do I need to remove that flange that the pulley for the pull start bolts to or is there something with the starter or the neutral indicator that needs to be removed or is there something else that would be holding that cover from coming free.
    Monroe MI
    5,787
    Mar 2007
    Texas
    5,045
    manual shows you exactly how to get it off. the pullstart dues have to come off and so does the flywheel and then that entire cover under the flywheel.
    ________________
    https://www.mikesatvfix.com
    Nov 2004
    Eastern Iowa
    12
    I bought the online manual but haven't found anything on specifically on swapping out the sprocket or removing that cover, any suggestions on how to brake that nut loose on the flywheel if that needs removed (in particular how do you keep the engine from spinning?)
    Oct 2008
    NB, Canada
    852
    What I do it put a socket wrench on the bolt, then hit the wrench with a in the direction to loosen the bolt. The quick jolt should break it loose.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    Always Hoping For a Maritime Trikefest- http://www.3wheelerworld.com/showthr...s-where-you-at
    "Wear Limits Are Just A Suggestion"
    louisiana
    1,499
    you will also need a flywheel puller,how do you plan on getting the cam sprocket off.
    Signature pic removed,becuase of no helmet.
    Mar 2007
    Texas
    5,045
    bought? heck check my sig, you can get the factory service manual for free. :P
    ________________
    juggaloclownz18's Avatar
    juggaloclownz18 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    The woods of 315 - NY
    303
    On my 200e i took off the 3 bolts holding the "pullstart cup" on, then the bolt for the flywheel comes out, then the stator slides off, then you can get to the flywheel, pull that with the puller (GET THE RIGHT ONE!!) then its all straight forward from there... (the left case will be exposed to take off to slide the front sproket out...)
    85 ATC250r (been waiting way too long!!)
    Tusk Hand Guards
    DG full exhaust (want different one)
    TAG handlebars
    +4 LSR axcaliber axle, carrier, hubs
    FMF Carbon Fiber reeds,
    K&N Filter/air box lid removed
    Motion Pro Twist Throttle
    Pro Armor Tether switch
    Seal Savers - long version
    23" Dirt Devil front - 22" holeshots back
    Soon to be ported/polished (got the work setup on trade)
