I need to replace the front sprocket on my 200e and I have the pull starter, sub transmission, and all the bolts out as well as the seals for the pull start flange and the neutral indicator but the cover that the electric start bolts to still will not come off. Do I need to remove that flange that the pulley for the pull start bolts to or is there something with the starter or the neutral indicator that needs to be removed or is there something else that would be holding that cover from coming free.
in the direction to loosen the bolt. The quick jolt should break it loose.
