Results 1 to 9 of 9
Thread: 125 M
    Apr 2009
    Oklahoma
    1,234
    125 M
    My son just bought a 125 M and we are un sure of the year. I have done a search on the forums for this but I have never seen a chain tightner in the rear like this. what all bolts on the rearend do I need to loosten to snug up the chain?
    Thankz for the help.
    Monroe MI
    5,787
    Aug 2009
    So. IL
    39
    loosen rear axle bearing holding bolts. the four on the sides around the center axle housing.bottom left should have a chain tensioner on it. adjust accordingly. chain should have about 3/8-3/4in play up/down use inspection hole on left side of drive chain case to check play. retighten the axle bearing holding bolts to 36-51ft-lbs. roll the trike forward recheck chain play through inspection hole. after all that you'll probibly need to check and adjust the rear brake if you move the axle a good bitjust adjust it by the wing-nut on the rear brake arm on the rearend. should be good to go.
    i'm just glad a service manual came along with mine. lol
    edit: i can get a pic of the exact ones if ya need it too.
    Apr 2009
    Oklahoma
    1,234
    Can you scan your service man and make a pdf file for it?
    Monroe MI
    5,787
    Check with Rob (rdlsz24) and see if he still has his, from this post (the link is no good).
    http://www.3wheelerworldforums.com/s...71&postcount=9
    Aug 2009
    So. IL
    39
    Quote Originally Posted by tulsamike3434 View Post
    nope, can't do that no scanner. maybe a pic for that page though.
    here's this anyway.
    http://photoshack.com/albums/userpic..._adjusters.jpg
    Monroe MI
    5,787
    Aug 2009
    So. IL
    39
    um, thanks. all i did was push the button. lol
    edit: doh, too much beer. you mean the pointers right? lol
    Apr 2009
    Oklahoma
    1,234
    Great job on the pic and it worked great! no slipage! running like a champ now back to the honda 110 lolol grrrrrrrrrrrrrrrrrrrrrrrrr
    P.S. thanks for your time and help!
