Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 43
Thread: 1984 Honda ATC 70 Project! *UPDATED 9-14-09*
    Santa Barbara, California
    1,161
    ****UPDATES ON PAGE 2****
    Got up at 5:30am this morning and drove 130 miles to get this little guy from a guy for $200. The only known problem on it was it needs an ignition coil. It didn't take me but 5 minutes to start tearing this thing apart to clean it and just go through it haha.
    First thing I noticed was the throttle was sticking so I thought it might have been the spring in the thumb throttle housing but it was the carb....It was just stuck with gunk. I have never taken apart a 3-wheeler carb in my life and don't really know where to start. Can I soak it in something? Or should I just start tearing it apart and cleaning it? Can I use WD-40 or should I go get some carb cleaner?
    Second up is the tires, the right rear tire has a hole in it and won't hold air at all so where is the best place to get some cheap tires?
    The plastics, tank and seat are in great shape with minor dents or scrapes and it appears to have not seen much use at all. The only thing I am not pleased with is the stickers on the rear fenders, gotta take those off as they are flaking.
    I got it to fit in my bmw wagon no problem, just loosened the handle bars and turned them down.
    Another thing, the rear tires were mounted differently.....the right side (the one with the flat tire had the hub on the outside of the rim so the air valve was on the inside of the rim and the left one was the opposite.....Which is the correct way?
    When I first got it in the garage:
    You can see some of the gunk in there:
    I just set the tank and plastics on, they are not bolted down or fitted:
    1985 Honda 200x
    Feb 2009
    michigan
    2,387
    atc 70
    nice pick up for 200.00 gonna be a fun little trike
    1985 ATC 250R
    . Team Red Trike
    OHIO
    2,857
    buy some evaporust at hardware and soak carb. Tires cheap at Tractor supply for 22.00 each if they are around you. You sure you have never took a carb apart?? I see a sand tire and a possible 200x in the pic? Is that your's?? Oh ya, nice 70 for the price........ the 70's are worse than potato chips, never just one!!
    HONESTLY - Sometimes I ride the 70 over the race 200X or the 350X, they are just sooooo much fun and like a super minibike
    1,161
    buy some evaporust at hardware and soak carb. Tires cheap at Tractor supply for 22.00 each if they are around you. You sure you have never took a carb apart?? I see a sand tire and a possible 250r in the pic? Is that your's?? Oh ya, nice 70 for the price........ the 70's are worse than potatoe chips, never just one!!
    I've worked on carbs on like RC cars and stuff but not trikes. And yes that's my 200x in the background but I have yet to take the car apart on it!
    And we don't have tractor supply around here.....I was gonna order online or something.
    Those sand tires and rims are going to be for sale, I never go to the dunes they just came with my 200x.
    What's the best way to get rust out of the tank, it is not completely rusted but there is some in there. And Evaporust is good to soak the carb in? Just take off all the rubber fittings and such?
    1985 Honda 200x
    May 2007
    Coshocton, Ohio
    1,815
    It looks you got a good deal to me. There isn't much to those carbs, just take it apart and spray it out with carb cleaner. Check the points, that could also be the problem. The coils rarely go bad with those.
    Appalachian American Racing
    the home of
    OT - But what can't we have SONIC drive-in or Tractor Supply?? In the Northeast?
    Were missing out here too on all the good stuff!!
    Last edited by Dirtcrasher; 09-06-2009 at 05:19 PM. Reason: Just elaborating on my crap........
    HONDALUVR's Avatar
    HONDALUVR is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2007
    ARKANSAS
    250
    Our Sonic has some hottie Car Hops ... Tight Khaki shorts .... ummmmm .... ummmm ... ummmm !!! Out tractor supply has some hot cowgirls as cashiers there ... Love Gals in Wranglers ... That climb shelves and put their young bottoms in your face and say ... "is that what you want mister ?"
    IT'S A TEAM GREEN THANG !!!
    OHIO
    2,857
    Here is a link to the site for the stuff. 21.00 per gallon plus shipping but I am telling ya, worth it..... http://www.evaporust.com/ Like daddio said as well, carb cleaner and air will work but if it is like the junk I work on.....soaking is a better option for severe problem carbs. Rode the 2hundy in the sand yet?? It is safe for the seals and will work in the tank as well. Biodegradable, easy on the nose and hands!
    Apr 2007
    UP of MI
    804
    Get yourself a POR15 tank kit. Don't waste your time or money with Kreem. Aerosol carb cleaner should be fine to clean up your carb. Most auto parts stores also have a gallon bucket of cleaner that works the best. They come with a tray you put your parts on and lower into the bucket to soak.
    1973 Honda CB350
    1973 Honda ATC70
    1978 Honda ATC90 (FOR SALE!)
    1982 Honda ATC110 (FOR SALE!)
    1982 Honda ATC200
    1983 Honda ATC200E
    2002 Honda Recon
    1,161
    Quote Originally Posted by Daddio View Post
    Yea he said they took it to a mechanic and it was getting very little to no spark and it needs a coil.
    How long do I let the carb soak?
    It also needs a new thumb part for the thumb throttle, it is stripped out and won't catch on the mechanism inside Anyone have an extra they want to sell?
    1985 Honda 200x
    1,161
    http://www.tractorsupply.com/vehicle...-2-ply-0303440
    Are those the tires you were talking about?
    1985 Honda 200x
    Monroe MI
    5,787
    HONDALUVR's Avatar
    Dec 2007
    ARKANSAS
    250
    I have a complete throttle assembly ...
    Aug 2009
    Culpeper, VA
    42
    Quote Originally Posted by inv3ctiv3 View Post
    I think this is the one you need:
    http://www.tractorsupply.com/vehicle...-2-ply-3000114
