So as of today I am a proud new owner of an 84ish YTM 225dx. Besides several problems the previous owner "didn't" know about, lets just say now she is a fixer upper. I was mainly curious about the forks, every 225dx I have seen on here has had the top of the forks about level with the handle bars, mine isn't even close. It actually has air fittings on the top, kinda like the valve stems on tires
The PO said that he didn't put much pressure in them cause it made it better for the trails. I have worked on a ton of machines, but this is my first atv so have no clue if what he was saying is accurate.
The rear axle bearing are bad, I've read denniskirk sells them, but Im not sure which are the correct ones. Anyone got a part # for the correct ones? The pullstart stopped working right after I bought it too, it figures. It doesn't catch, is this a relatively simple fix? If so, how do I go about it?
Also is there a place that sells individual engine gaskets? I would rather not pay $50 for all of them when I only need the gasket that seals the cover under the pullstart.
Thanks alot
