ive been tinkering on an off with my 83 or 84 225dx for alittle bit now and cant get it to stay running. here's a run down of whats been going on with this thing.
i got the bike from a buddy for hella cheap as it was in a field for a few years. said it ran when they parked it then it gradually found its way into the lawnmower graveyard he had goin on.
i started by cleaning the carb and replacing a few jets and o-rings with the proper replacement. put a new plug and battery in it and it turned over great but wouldnt start. it had great spark and what felt like good compression (dont have a tester). fast forward to about a month ago. we got it run after pouring some gas into the carb. it took some coaxing and at first would only run for a few seconds then die. it would then take a few minutes before it would run again. we finaly got it to run for about a minute or 2 by playing with the throttle. then it died and wouldnt restart. while it was running i noticed oil coming from the crankcase breather hose that came loose from the air box.
today i changed the oil and tried to start it via the elctric starter and it wouldnt start. i got it to start by pouring alittle gas in the carb and using the recoil start (same way we got it running before). it ran for about 1 minute then died and wouldnt restart. i decided to check the valve timing but the book (clymers) was very vague. im assuming the little groove in the threads on the flywheel sight screw hole deal is what the flywheel timing mark should line up with but again it didnt say in the manual. i looked at the timing gear and the mark on the gear was at about the 1o'clock position with the stationary mark at the 12o'clock position. both whould line up with the perspective marks correct?
im sure the carb needs some adjusting and posibly the timing needs to be reset but why wont it start with the electric start? it turns the motor over just fine and its getting spark with both the electronic and recoil starters. i want to get this dude up and running for the misses this winter so i can ride my bike and she can ride this. im kinda selfish i guess![]()
any ideas would be greatly apprecieated as i cant really afford to take the bike in and have a shop look at it.
thanks
mike
