Results 1 to 15 of 16
Thread: Oxygen sensors??
    Question Oxygen sensors??
    I'm doing some work on my truck, the "service" light has been on for some time now. I found a snapped off OS and plan on replacing it. It is located PRIOR to the cat.......
    The deal is, they are 160$ and thats not OEM which must be double that
    Anyhow I have 2 questions:
    1) Anywhere I can find one a bit cheaper for a 94 Toyota V6 4x4 OS, located PRIOR to the catalytic converer??
    2) Without searching online, What do they do?? I imagine that prior to the CAT, it's mostly raw CO and other spent exhaust fumes, but apparently there must be oxygen present that sends a signal back to the main computer and says (Hey!, do this to the fuel mix!!)
    I'm sure it saves gas mileage and helps with emissions (although I am not even tested being a 10yo truck) but any gas savings will surely pay for the sensor in time.
    I'm just curious as to there function, seems odd to have any oxygen present but it must be very minimal.
    I guess the 160$ was just a kick in the face I wasn't ready for.
    Any thoughts or input is appreciated, thank you.....
    na
    5,702
    Toyota Truck sensors are expensive..No way around it.
    I am sure you can find some hokey dokey, El Guapo unit, but many times they require you to splice the wires, and end up not working correctly.
    That sensor is Primary Air Fuel Mix for the ECM.
    With it inoperable, you computer is commanding open loop fuel and timing control, much the same as running with a choke on, with a old carb equipped car.
    You are probably loosing Approximately 30-35% of your fuel mileage, that the truck is capable of getting.
    EDIT..I would price OEM..Many times they are cheaper than aftermarket as of late becuase of the Economy.
    Proudly NOT a member of
    "Team on the Teat"
    6,819
    I've changed them several times and its defiantly a big difference on gas mileage . If you've ever had one go bad on a dodge PU it feel like a v8 motor running on 6 cylinders . If you want to buy generic , I would go to a good auto store like NAPA or Bennet .
    1984ATC200S's Avatar
    1984ATC200S is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2008
    New Brunswick Canada
    222
    Mine before discount was 145$ Bosch for my 93 sierra, walk out with it for 85$, i would try and find a good parts store and do most of your business there, mine treats me well, as I've been dealing with them for the last year.
    1984 200s
    1984 big red
    1980 Kawasaki Invader 340 liquid
    1993 GMC sierra, 4.3L automatic
    1990 Chev Scottsdale -parts
    1989 Chev wrangler 4.3L 5 speed- parts
    Chevs are for parts GMC's are for driving
    All I can say is you definitely don't want a universal.
    Monroe MI
    5,787
    I bought a Bosch also, 30k miles on it, so far.
    They have a special O2 wrench set available at AutoZone (loan a tool), if you don't have one. Makes the job easier on some vehicles.
    racerxxx's Avatar
    racerxxx is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2008
    Pennsylvania
    383
    Here you go DC--Genuine for $108 It does not give the location but if you can get the OEM # you can search it on that site by P/N
    http://www.partswebsite.com/pagetoyo...n=3&type=parts
    Try http://www.ineedtoyotaparts.com
    They have it for 102.36 + 10.24 for shipping
    Get the OEM # and start the google process, I searched for about 10-15 and found these 2.
    Both of those sites are genuine Toyolla parts.
    Enjoy
    1985 Honda 125M (My first Trike--Still have it)
    1986 Honda 250SX
    1981 Honda 110
    1982 Honda 110
    1986 Yamaha YFM80 (Sons quad)
    Past rides: 1983, 1984 200X, 3--1985 Kawasaki T-3
    1987 CR-80, 70's vintage XR75, RM 370
    racerxxx's Avatar
    Oct 2008
    Pennsylvania
    383
    I can't get it to take you directly to the part, but in the search box type in oxygen sensor and you'll find it.
    Also, if you're looking on a genuine toyolla site it is under electrical, powertrain control, the search for OS--stupid place to list it if you ask me.
    1986 Honda 250SX
    1981 Honda 110
    1982 Honda 110
    Apr 2006
    Crestview, Florida
    2,429
    rockauto.com cheapest auto parts you can find.
    Rides
    85 ATC350X
    85 ATC200X
    Apr 2007
    UP of MI
    804
    Quote Originally Posted by Erics350x View Post
    Beat me to it.
    1973 Honda CB350
    1973 Honda ATC70
    1978 Honda ATC90 (FOR SALE!)
    1982 Honda ATC110 (FOR SALE!)
    1982 Honda ATC200
    1983 Honda ATC200E
    2002 Honda Recon
    Feb 2009
    Rome,NY
    1,046
    i had a couple wires break on the wifes car so i put them back together ... works fine
    Thanks for all the information and suggestions guys :
    I should be up and rolling again tomorrow so I have some time to deal with the sensor. But, if it makes it run rich, I don't want to carbon crap up over 30,40,50$. I'm watching my money but I have to use my head too!!
    Thanks again!!
    Soutwestern PA
    2,040
    I owned a Tacoma from 1997-2009 and the oxygen sensors, cat, and mass air sensors are the only parts I had trouble with.
    Had a big chain reaction where a clogged (cheap aftermarket) cat converter made the oxygen sensor go, then the mass air sensor went bad, then the other oxygen sensor.....
    I am not sure of the whole cause and effect, but after I stopped replacing the parts with Midas and used junkyard stuff, I never had another problem.
    Now, I only replace with OEM Toyota parts - more $$ up front, but no worries in the end.
    Apr 2008
    somerset ma
    1,822
    you probably should have grabbed the one off of that truck that was at W.Z's
    cox's Avatar
    cox is offline Just Too Addicted Arm chair racerJust too addicted
    Aug 2009
    Edmonton alberta canada
    552
    go to the wrecker. that sensor is generic across most years of 4runners and pickups. cost you maybe 5 bucks, so buy 4 just in case.......
    R.I.P. Yamahondaman
    Still practicing my NoobiX cube, take it easy on me...
    1982 Yamaha YT175J ( Not much left but the 's)
    1982 Yamaha YT175J
    1983 Yamaha YT125K + 175J =
    1984 ATC 200ES BR - running again - Camchain noise holding me back....
    1984 ATC70 -SOLD-
