Results 1 to 15 of 19
Thread: Best way to get off a gasket?
    Santa Barbara, California
    1,161
    I am replacing the head gasket on my '85 200x since it was starting to leak and I am selling it, don't like selling things that are broken so I figured I would change it out. The old HG is stuck on both sides and is proving to be quite the to get off with a scraper. Can I spray something on it that is safe to spray around the piston/valves and will start to dissolve the gasket material?
    1985 Honda 200x
    Sep 2008
    845 New York
    2,302
    engine cleaner?? or a rag soaked in gas
    1985 Quad Killer
    1985 Mini Raag
    1985 Green Gobbin X2!!
    1990 Kawasaki 300sx
    R.I.P
    85Tecate is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2009
    Iowa
    442
    Get one of those wire wheels for a drill and go to town. Press pretty hard and you should have no problem taking the old off. This is what i always use, but usually i first scrape what i can with a gasket scraper or flat razr blade.
    Nov 2008
    ontario
    1,055
    i would let it soak for a couple hours with gas or gasket remover just to soften it and then a credit card and go to town
    proud owner of a trx300ex quad and an 85 atc 70
    1,161
    Ok one last question, to do the "water" on the valves test can you use water? I've watched my mechanic do it but forgot to ask what it was....Or should I use gas?
    1985 Honda 200x
    Nov 2008
    ontario
    1,055
    i would def use gas, water will sit in there and cause some rust, i would lap them to be on the safe side
    Apr 2004
    Brigham, Québec, Canada
    1,528
    Did you never heard of Gasket remover by Permatex. It's some nasty stuff. It come in a spray can. Shoot, let the gasket bubble and scrap off. It will also remove the paint on the aluminium and the skin from you body...
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    Oct 2007
    Minneapolis mn
    4,067
    Buy it a drink, talk dirty to it.... Try a heat gun and a scraper... The water trick, you can use water, just blow it off with compressed air when your done and give it a decent spray of wd40....
    Sep 2005
    Lipetsk, Russia
    2,824
    Be careful not to damage the flat surfaces, don't use a metal scraper... use a wooden or plastic one, like a stiff spatula or some chit like that.
    I'm back in the USSR...
    Sep 2007
    100mi west of Chicago
    3,582
    Permatex gasket remover is the stuff to get. I've used it to take off a Toyota head gasket, trike head gaskets, and the black paint off my 200x forks when I wanted them to be plain metal.
    Rob
    I use a long EXTREMELY sharp gasket chisel, but you have to be very careful about how it's used. Wire wheels and scotch brite pads do remove aluminum so I avoid them.
    But, just like this one I have and wood chisels, they are sharpened only on one side for a reason. They truly are meant to be used upside down from what you would think so that they don't bite in. The sharpened side should be against the work surface and the flat side away from it.
    That gasket remover works real well on plain gaskets, it eats the glue and like someone said - your fingers, paint and everything else it touches. Some guys say engine cleaner works too.....
    bigred44's Avatar
    bigred44 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    Ithaca Ny
    361
    Instead of a wire wheel on a drill i always use a small one on a dremel after i get what i can with a razor blade. This way you can be a lot more careful not to scratch up the aluminum.
    '84 ATC 110
    '84 200x
    '85 350x
    '86 125m
    '03 Shadow ACE 750
    '05 Brute Force 650
    Jan 2005
    RI
    2,530
    i prefer a dremel cutoff wheel
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Sep 2009
    Suring Wisconsin
    967
    The Permatex remover works great but becarful, it is as nasty as you can imagine. Brake cleaner works to.
    Monroe MI
    5,787
    I've used carb cleaner, engine cleaner, starting fluid, gas, pretty much everything volatile, except gasket remover.
