Results 1 to 15 of 22
Thread: whats the trick to getting the triple trees off?
    Escanabajosh's Avatar
    Escanabajosh is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2009
    U.P. (upper michigan)
    352
    i have my 350x down to the frame but i cant get the triple trees off. i beat em a bit with a 2x4 and but i don't wanna break nothing, any tricks or tips?
    lol......i just looked out my window the neighbor is rippin down the ally on his sled! we got like a inch of snow on the ground!
    Oct 2009
    Morgantown, WV
    29
    I just took mine off Sunday. You did take the threaded screw off after you took the crome cap correct? Mine fell right off after that.
    Oct 2009
    352
    there was a big crome one with a dome top that i took off then after that a washer and that was it.
    what threded screw?
    thanks too eh
    Monroe MI
    5,787
    Back in Happy Valley
    833
    Sounds like you didn't take the top piece off yet. Loosen the bolts and slide the fork tubes out, and once you have that chrome nut off with the washer the upper triple will come off, then you have another threaded piece and once that it removed it will fall apart in your hands...
    86 350X
    85 350X daily rider
    LC 250R
    85 T3
    86 T3 roller
    85 250sx beater
    Oct 2009
    Morgantown, WV
    29
    Make sure you are carefull because you will have ball bearings everywhere.
    Oct 2009
    352
    i got the forks out and the big nut and washer off but it ain't budging? should i try a board and a B.F.H.? i'd hate to break anything. i had a puller on and it wouldn't even budge, i might have bent up what looks to be a bearing race under the top tripple.hope a new one comes with the new berrings!
    so after the top tripple is off then there will be another bolt to remove for the bottom to come off.
    Yes there is another nut, and the nut that tried to remove them without reading a manual or opening his eyes
    You'll figure it out............
    Welcome to 3WW
    N/A
    5,818
    the correct way to get 350x tripples out is to have the correct tools and let the s in the tool box.
    Oct 2009
    352
    okay i put the away...lol
    i''m going to wait i guess till i can buy i book for it.
    this might be a dumb question but do they ever get stuck somehow?
    i think i'm to the part where it falls apart in my hands but it ain't budging?
    thanks for the help guys
    Oct 2007
    SouthShore - MA
    653
    How about a pic of what you're looking at.
    Basically theres 2 nuts on the top of the tripple holding it on.
    Tionesta, PA
    5,747
    Have you removed part #11 (top right) yet? I use a screwdriver and a to remove that part.
    the removal order should be
    top chromed acorn nut
    4 - 12mm headed bolts that clamp the triple to the forks
    then the top triple
    then the #11 seen in picture above
    then it should slide down and out sending you scrambling for a magnet to retrieve all the ball bearings that just fell onto your floor.
    Have you removed #11 yet? It is standard thread - and as I said - just us a flat-headed screwdriver as a "chisel" of sorts to bang it loose.
    Monroe MI
    5,787
    Quote Originally Posted by Escanabajosh View Post
    Here's a direct link to the manual this time.
    http://72.52.143.80/~trikes/atc350x_...vicemanual.pdf
    ^ See!!, it's all your fault Mike
    "I beat on it with a and 2x4" Oh god kill me now..............
    Sep 2007
    100mi west of Chicago
    3,582
    Are you talking about the top handlebar bridge? Mine was rusted onto the stem on my 200x. Took lots of penetrant and moving back and forth to break it free.
    Rob
