Results 1 to 15 of 17
Thread: 1985 Big Red 250, One back wheel has no power to it
    May 2008
    Pennsylvania
    19
    Hey guys, was out riding the big red last night and all the sudden I started to hear a clicking noise from the rear end. It was pulling to the one side and I stopped and checked it out and it turns out my right rear tire was the only one spinning, the left rear tire has no power to it at all. Anybody have any ideas to what the problem could be?
    Apr 2009
    Saskatchewan
    119
    My father in-law had the same problem on that model of trike it was the hub on that side that was shot. If you take the tire off and the spline is still turning thats the problem. Something to check anyway.
    1985BigRed250ES's Avatar
    1985BigRed250ES is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Rison, Arkansas, United States
    397
    if the hub got loose and was ran that way for a while the hub and axle splines are probably no longer there.
    1985 Honda BigRed 250ES
    runs good all original
    Restoration in progress:
    1980 Honda ATC 110
    1985 Honda ATC 250SX
    1982 Honda 200ES BigRed
    1984 Honda 200S
    1984 Honda 200S parts bike
    1985 Honda ATC 110
    1983 Honda ATC 110 parts bike, runs but smokes
    Feedback link: http://www.3wheelerworldforums.com/s...ad.php?t=95258
    NewfieBish's Avatar
    NewfieBish is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2008
    Cupids, Newfoundland
    267
    defenitely sounds like a stripped hub, my buddy had it happened to him, im not sure what he done with it, i think he tacked the hub onto the axle with some weld, but thats not the right way to do it.. I'm not sure if a pin would work or something like that?
    85' ATC250R
    If the axle splines are now junk, this is one time I'd advise someone to just weld it together and call it a day. It can always be ground down to remove it and it gives you time to find a good used axle and hub......
    If you want to protect things near it from melting, put LOTS of DRIPPING wet rags behind where your welding to keep it from heating up and hit it with the garde hose immediately after welding.
    May 2008
    Pennsylvania
    19
    Alright sounds good I'm gonna tear into it tonight and check it out, I did have to tighten that hub up before I left for my ride last night so I'm pretty sure thats the problem. I think I'll just have it welded, thanks guys
    rebel33382 is offline At The Back Of The Pack Arm chair racerFirst time rider
    New Orleans, LA
    201
    a buddy of mine drilled a hole through the hub and axle and put a grade 8 5/16" bolt and hes had it like that for awhile!
    1984 200ES first Shaft driven big red with reverse!
    85 Big Red 250ES with a rebuilt top end!
    May 2008
    Pennsylvania
    19
    I Took the hub off, the splines on the inside of the hub are pretty bad. The splines on the axle dont look really too bad, I'm going to take off the other hub and compare the two sides to see how the splines should normally look. Theres no way to weld the inside of the hub because it sits inside the swingarm and rides on a bearing. So, Can it be welded from the outside? Also, are these the only bearings in the rear end?
    Monroe MI
    5,787
    If the splines on the axle are still good, get a new hub. Don't weld it.
    May 2008
    Pennsylvania
    19
    I'll take the other side off tomorrow and check it out. Does anybody know if any hubs for other three wheelers are interchangable with the big red 250? Besides the sx's...Looked on ebay so far, cant find one.
    Monroe MI
    5,787
    May 2008
    Pennsylvania
    19
    I'll have to try that, I cant find one anywhere. Okay, I took the other hub off, just to compare the splines on each side of the axle. The splines on the side with the brake hub are perfect, never had any trouble over there. The splines on the other side where the hub got loose arent really too bad. I can notice a difference in the sides, but its not much. The perfect side is more rigid, the splines are more defined, and the other side there just a slight bit rounded off. Do you think I'll be safe with just buying a hub? There far from smooth on the side thats bad, and they still have pretty decent grooves in them.
    Eastern Long Island
    1,688
    If you need parts I can hook you up!
    http://www.3wheelerworldforums.com/s...ad.php?t=97483
    They are as close to new as you are going to find. Te only thing I want to keep is the drum. Shiping shouldn't be that bad either.
    Lots O Trikes!!!!!
    May 2008
    Pennsylvania
    19
    I Think I'll just need a hub on the left side. The left hub and the right hub are different sizes. I put the right hub on the left side to see how the splines would hold, and they didnt at all, and then I looked at both sizes and felt like an idiot. I'm pretty sure the axle is going to be fine, I have everything apart and the bearings are bad so i'm going to do those while I'm in there. I need the left hub though, looking at it from the back. The hub opposite of the brake drum.
    Rittman, Ohio
    6,276
    These are from an 86 TRX250. I think they fit 250ES and 250SX. $60 shipped takes the whole pile. Axle and hub splines are perfect.
