Hey everyone. This is my first post on here in the 4 years that I have been a member of this forum. (Sorry been splitting cases plating bolts and powder coating frames.. hehe) There are some very nice restorations on here by the way. I love view that stuff. I will show pics of mine when i get it off the ground just been playing with frame and plating last 2 years.
My R that I ride, I swapped the original motor last year with a stock motor that I bought off ebay. I have been having trouble keeping it running smoothly. It seems to bog at about 1/2 throttle, and sputters rich smoke. Runs extremely rich. (Checked plugs. Oily)
Here is how this story all starts. Last July I threw this motor in after cleaning up cylinder and rings with a hone. Compression is good. Holds good @ 160psi and still holding. Last year I attempt to fire this motor up. It backfired three times. I trace the problem to faulty eaten up magnetic pickup strip on flywheel. I replace the flywheel with my good one and and away she runs.I have maybe ridden it 6-7 times since then, and noticed it sputtering rich and hesitating at ?? 3/4 throttle, then starting doing it at 1/2 throttle. I start with the carburetor, viton needle and float good and level. All jets stock. I look at reed cage metal reeds look a little fatigue, I throw in v force 3, and she takes off again considerably. Like a raped ape!
Still a little hesitation after 3/4 throttle. I go for 3 hour trail ride. Come back, shut er down, check plugs, plugs very dark. I fire her up again, Extremely loud backfire!
Start her up again. Seems to run fine. Start her up week and a half later, now hesitates at half throttle again, still running rich. I go through a week of hell swapping for leaner jets, different needle positions, different reeds, different carburetor, SAME PROBLEM. Bogs at 1/2 throttle, runs extremely rich. Idles beautiful. Nice chocolate brown color on the idle circuit with a new plug. Returned all parts back to stock, jetting, reeds, everything, problem persists.
I'm going back to popping off the mag cover and checking all electrical specs if my dipstick brother ever remembers to bring me the shop manual, and it stops raining :mad But what I am starting to suspect is electrical related, and what my main questions are?
On the original flywheel. What would cause the magnetic pickup strip on the flywheel to be all gouged up? Imbalanced crankshaft? Bad Woodruff key? etc?... I am, wondering if this is happening now with the good flywheel I have on there now.
Also... Would this theoretical electrical issue mask a jetting issue? This is occurring in a specific RPM range? It almost sounds like there is a rev limiter when this occurs at 1/2 throttle..
Has anyone ever had this experience, and is it electrical, crankshaft, woodruff key,stator, flywheel related?![]()
Any help with this issue would be greatly appreciated, and prevent me from using rogaine.. hehe.. I'll owe the lucky one aand a couple of quarts of HP2 smoke.
