Results 1 to 15 of 15
Thread: ATC 90 hydrolocked?
    Mar 2009
    Utah
    203
    ATC 90 hydrolocked?
    I have a 90 which had no compression. so i took it apart and found that the gaskets were bent and blown and that the piston has a small quareter inch wide, barely visible scrape/dent on it. does this mean i should replace the piston?
    3 wheelers:
    '85 ATC 110 (its my first restoration!!)
    Saving up for a 250r later this year!
    Nov 2008
    ontario
    1,055
    i think we need some pics but sounds to me like you bent a valve
    proud owner of a trx300ex quad and an 85 atc 70
    Monroe MI
    5,787
    Mar 2009
    Utah
    203
    K. i'll try to get them tommorrow. if it's a bent valve, the engine turns over just fine.
    3 wheelers:
    Pafrig's Avatar
    Pafrig is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2009
    ALASKA
    278
    do you have normal compression?
    Des Moines, IA
    1,303
    The first thing he said was that he has no compression.
    Could it be the normal dent that is in some pistons? Sounds like you found the problem with the gaskets being blown.
    God knows they're not looking to make any effort to do anything, never mind move their foot to shift. If there was something that dispensed Cheetos every time they shifted that might be a different story. Welcome to America, where the biggest is best and even fat people who are too lazy to shift can climb a mountain.
    Mar 2009
    Utah
    203
    Well, it has the normal indents, but where one is supposed to be it's all bent and messed. The photo's not too good, but here it is. And yes i know the engine's rusty and the cylinder is too, but i'm doin a makeover and derust on it to get it runnin
    3 wheelers:
    PA
    3,515
    if it's rusty....bore that pig!!!
    why mess around?
    WWW.HREATV.COM
    Mar 2009
    Utah
    203
    That'll come later. It'll get done. it still turns over just fine and is now in a place where i'm gonna clean it up. But will it still work with the piston in the shape that it is?
    3 wheelers:
    PA
    3,515
    if the bore is rusty then no, it shouldn't run good at all.
    dents never bothered me on my little trikes. just sand the sharp edges with 220 so you dont get hot spots.
    WWW.HREATV.COM
    6,819
    That doesnt look like a stock piston to me and why is it so clean with no carbon was it ever run ? possibly an old NASA big bore piston @ 54/55mm .
    Mar 2009
    Utah
    203
    possibly. it does say it was made in 99, only 2 years before the trike was last registered so it looks fairly new
    3 wheelers:
    Mar 2009
    Utah
    203
    And it is also possible that it's never been used, because it's been sitting for about that long too
    3 wheelers:
    PA
    3,515
    i never seen a date on a piston.
    WWW.HREATV.COM
    Mar 2009
    Utah
    203
    it says something like 99 on the top. it might just be nutin though
    3 wheelers:
