Results 1 to 15 of 22
Thread: 84 Honda 200es troubles HELP!!!!!!
    Oct 2009
    ohio,usa
    11
    Looking for help on my 84 200es, bought from a friend who had left it set for a year or so with bad gas. Unable to revive carb so I bought a new one and installed, started right a way and idles perfect! At about half throttle it starts to sound like a two stroke,misses pops cracks no power. (new spark plug) I have downloaded a manual but that has not been much help. I have removed the muffler,seems to be plugged,also couldn't get the spark arrester out to clean it. I am really at a loss as to what I should do next. Any help would be great!!!! I hope I am posting this in the right place as I am new to this site. Thanks in advance, Bill.
    Nov 2004
    OH.
    2,487
    Welcome to the site Bill. Not sue about your problem. Where in Ohio are you? I'm more of a hands on guy.
    Oct 2009
    ohio,usa
    11
    Kingston, where are you?
    Nov 2004
    OH.
    2,487
    Not sure where Kingston is. I'm about half hour north of Columbus. There are quite afew of us on here. Mostly northern Ohio.
    Nov 2005
    southern maine
    99
    have you tested compression yet?
    Monroe MI
    5,787
    Oct 2009
    ohio,usa
    11
    I wasn't able to check compression, my set doesn't have the correct adapter. (Snap-On automotive set) It appears to have good compression, starts very quickly, idles perfect, although when I removed the new plug it was already loaded with carbon. I cleaned it and checked valve adjustment and they were tight. Adjusted valves, still same problem. It starts cutting out at about half throttle, when you go full throttle it sounds like its on a rev limiter.
    Oct 2009
    ohio,usa
    11
    Quote Originally Posted by drkilldrmz View Post
    I replied to your question above, sorry.
    Oct 2009
    ohio,usa
    11
    Smile
    Quote Originally Posted by MonroeMike View Post
    Welcome to 3ww.
    Thanks! Glad to be here!
    Nov 2008
    ontario
    1,055
    have you checked the air filter? (you most likely have), are you sure you bought the right size carb, it might be putting out too much gas
    proud owner of a trx300ex quad and an 85 atc 70
    Oct 2009
    ohio,usa
    11
    see message below, thanks.
    Oct 2009
    ohio,usa
    11
    Quote Originally Posted by daniel_250r View Post
    I believe it's right, same size, spec for 84 200es, air filter is removed.
    6,817
    Did you buy one of those chinese knock off carbs ? If so It might need to be jetted for your motor .
    Oct 2009
    ohio,usa
    11
    Probably, came from Ebay. Any way to check to see what jet it has?
    Nov 2008
    ontario
    1,055
    thhe jets should have tiny numbers printed on them atleast my honda ones do. another thing you can do is clean the oem jets well and use them
