Results 1 to 9 of 9
Thread: 200x rear shock.....
    4cfed's Avatar
    4cfed is offline Just Too Addicted Arm chair racerJust too addicted
    Oct 2009
    wisconsin
    619
    i searched and couldnt find what i needed.. so... ima bigger guy 5'11'' 255 and i was wondering if there was a direct or close to direct bolt on rear shock that would suit my weight better?
    86 200x, 1st gen 200x axle,400ex hubs,fmf megamax2 muffler
    Three wheeler guys probably have the biggest balls out of all the ATV/Motorcycle riders. You just have to be a little twisted to ride them, and you have to be a great rider to do so.
    'let those who slide decide'
    louisiana
    1,499
    you can use the 350x shock but you would have to fab a mount for it or get your 200x shock rebuilt for you weight .
    Signature pic removed,becuase of no helmet.
    4cfed's Avatar
    Oct 2009
    wisconsin
    619
    hmmm.. i got abuddy with a 350x and a bunch of parts.. and he is good with a welder.. supposto go riding out at his place this weekedns o ill have to look into that
    Monroe MI
    5,787
    4cfed's Avatar
    Oct 2009
    wisconsin
    619
    good info thanks! i dont want it to sit higher id just like it stiffer ( gonna spend alot of time sideways) and i want the most out of my slides and dont want it to compress and hooked harder .. i like stiff rear suspension for winter time
    6,803
    They use to make HD aftermarket shock springs for the 200x because when you install a +2 swingarm you need a stiffer shock . I know you prob dont have the longer swinger but the spring would probably do the trick . Also did you tighten the springs nuts down to make the shock stiffer ?
    4cfed's Avatar
    Oct 2009
    wisconsin
    619
    there about half way down right now
    6,803
    If you got a spanner wrench crank that puppy down till it feels good .
    4cfed's Avatar
    Oct 2009
    wisconsin
    619
    ok.. ill have to find a spanner wrnech... did my last 200x with screw drivers and it took me a half hour to do it lol...
    went riding today and she feels pretty good sideways in the grass and mud so i prob wont have to go mutch more to get it where i want it
