Results 1 to 15 of 16
Thread: 84 250r wider rear stance?
    sbjones73's Avatar
    sbjones73 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    wisconsin
    414
    ok i remember reading some where that i can put on some rear hubs off of some other trike or quad that will widen my rear stance by an inch or more.
    i want to use my stock rear rims and stock rear axle. or if another rear axle (easily found) will do this.
    any help with this would be great.
    thanks!!!!!!
    84 250r gone,
    87 suzuki lt250r trail machine, gone to fund ice racer,
    85 250r ice racing project started !!!!!!
    Feb 2009
    michigan
    2,387
    you should be able to find spacers easily
    1985 ATC 250R
    . Team Red Trike
    Alberta, Canada
    215
    Or you could get your @ZZ off the seat and ride it right. Just a thought. Lean in and gas it. I can peel a stock 84R sideways on dry pavement. (I don't suggest anyone try this) Why Can't you?
    Our bike (I have the same model) is built VERY well. Maybe you just need lessons.
    Sorry if I sound righteous but I can. What are you riding through that you need an extended axle?
    boosted96cobra's Avatar
    boosted96cobra is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2007
    n utah
    279
    Quote Originally Posted by SPD FRK View Post
    WOW can I have your autograph? Can you really do that? What's the best way to ride devils dune?
    Seriously he was asking how to widen his bike. Not how to ride. Yes in the past I tried spacers and yes I hated them. I like the stock stance with 3/5 spaced wheels. I do not like them wider. If it was me I would go the 3/5 wheels and make sure your washers spacers are before the hub not after and leave it. But that is my opinion.
    http://i291.photobucket.com/albums/ll292/sagep11/IMAG0069-1.jpg
    84 tri-zinger
    85 ATC 250r
    86 TRX 250r
    85 ATC 350x
    86 ATC 200x
    Monroe MI
    5,787
    Soutwestern PA
    2,040
    Yep, buy some quality new or used wheel spacers on eBay. You should be able to find 1.5" or 3" sets. Only takes a few minutes to bolt them on and away you go.
    Apr 2003
    Bay Area CA.
    2,638
    I just ordered a new set of 1.5" spacers for my 350x on ebay. Paid just under $40
    1985 350x
    1985 atc70
    2006 ltz400
    2017 z125pro
    Jul 2006
    iowa
    451
    400ex/300ex hubs are the ones that are commonly used to get a couple inches. Im not positive they will work with your axle/rims but im pretty sure they do. (check before you buy them)
    current rides:
    05' 400ex
    02' yz85
    84' 200es big red
    84' 200s with tlr200 engine project (almost done)
    84' atc 110
    83' 225dx with 340cc kohler sled engine
    Jun 2003
    englishtown NJ
    2,676
    400ex or 450r hubs will fit and fit the lug pattern on the rear wheels. It will make it 3-4" wider.
    Jul 2006
    wow... listen to you!
    Bring his freak on down to ASSachusetts, we'll test out his MAD SKILLZ
    sbjones73's Avatar
    wisconsin
    414
    deathman, will the stock ones make it 3-4" wider total ?
    thanks
    84 250r gone,
    4cfed's Avatar
    4cfed is offline Just Too Addicted Arm chair racerJust too addicted
    Oct 2009
    wisconsin
    619
    400ex hubs will give you a wider stance... and are a direct swap.. im running dura blue 2.5 spacers on my x and love them...
    86 200x, 1st gen 200x axle,400ex hubs,fmf megamax2 muffler
    Three wheeler guys probably have the biggest balls out of all the ATV/Motorcycle riders. You just have to be a little twisted to ride them, and you have to be a great rider to do so.
    'let those who slide decide'
    Jun 2003
    englishtown NJ
    2,676
    yes, stock 400ex or 450r hubs will make it 3-4" wider. The reason is the 83/84 250r and 83-85 200x hubs are flat(no offset). Most of the newer hubs have a 1.5 - 2" offset in them.
    sbjones73's Avatar
    wisconsin
    414
    thank you very much, that is what i needed!!!!!!!!!!!!!!!!!
    84 250r gone,
