Results 1 to 7 of 7
Thread: 1980 Honda Act 110 Ignition Coil Interchange?
    Nov 2009
    Tx
    3
    Hello to all. I was wondering if anyone knew of an aftermarket coil that will fit this bike or maybe if one from another atc will work. Thanks in advance.
    Feb 2008
    Orange County California
    726
    Why do you feel your coil is bad?
    I am sure any of the pre 82 string pullers would work, but there are much more experienced here that can properly answer your question.
    Welcome aboard!!!!!!!!!!!!!!!!!
    1986 ATC250r
    1984 ATC70
    Monroe MI
    5,787
    Welcome to 3ww.
    There's some on ebay right now.
    Have you tested yours, to make sure it's bad?
    Sep 2007
    100mi west of Chicago
    3,582
    Unfortunately I have found that 79-80 110 are the only ones that will work. I have tried to put used ones that I found cheap from a 70 and 90 on my 79 110, and neither of them fit quite right where it bolts to the frame. The plastic coil cylinder is too wide to fit. Not sure if the new ones on eBay fit correctly or not. I would ask for a width measurement before buying.
    Rob
    Nov 2009
    Tx
    3
    My coil is broken. The wire that goes from the coil to the spark plug was very loose. I tugged on it and it came out.
    Quote Originally Posted by rdlsz24 View Post
    Rob
    Rob was the only problem you had that it would not fit correctly . I just need it to work. I can find a way to mount it .
    I am not the original owner.I picked this trike up about two weeks ago. It just needs some TLC.
    Sep 2007
    3,582
    That wire that you pulled loose should be able to be tightened back onto a screw. You get the bare wires and they catch on the screw and you tighten it by hand. Kinda hard to explain.
    Rob
    Nov 2009
    Tx
    3
    It does not I have looked at it. You can see where the wire was torn. The only part that I have seen that screws on is the spark plug cap.
