I am hooking up the headlight on my new (new to me) atc 90 and cannot figure out what to do with the blue wire that comes off the headlight? Enclosed is the wiring diagram.
Thanks,
Thanks,
i am not 100% on this one but the Blue wire is for either High or Low beam and the earky 90s did not have that option in the switch just on or off
1985 Tiger 250LC
1985 Tiger 200LC
1985 ATC 350X
1985 ATC 200x
1973 ATC 70 (resto project)
and many more!!!
Blue Line Graphics
it is definatley for high beam, i have determined that. The switch on top of the headlight (factory switch) has 3 positions - off and then 2 other positions? Does one position turn on the tail light and the other the headlight?
Headlight and tail light come on at the same time.
Nicholson 500x (Project)
Nicholson 185s
PK Racing Suspension 70
A+ Inc Suspension 70
AWS Aluminum 90 frame
SO, the blue wire is nothing? Doesn't seam right??
In all Honda motorcycleand ATV, the blue wire is the High beam
1986 ATC500X
1985 ATC250SX
1985 ATC200X
1985 ATC250R
1986 ATC250R
1984 ATC250R
1981 ATC70
1984 ATC70
1985 ATC70
Custom built ATC70 / 250R laydwon swap
1986 ATC250SX FATCAT
Thats what I figured but per the diagram I don't know where to hook it up?
I think I just figured this out. There is no kill switch on this bike. So this is my take - position # 1 = bike is off, position # 2 bike is in run mode, position # 3 bike is in run mode with lights on.
That's how my 77 90's are....They have a separate kill though from the headlight... the headlight positions are- Bike off, Bike on H/L off, and Bike on H/L on. There is no high beam.
2) 1977 Honda ATC90
2)1985 Tecate
2005 Banshee LE
01 Honda 300EX
74 Suzuki TC100
66 Honda 305 Scrambler
my 1973 90 has the switch on the light - like yours - but has nothing to do with the kill switch. It is light off / light on lo / light on hi
atctim - where does your blue wire mount to?
From the 1974 owners manual.
http://campaigns.hondampe.com.au/Mot...own74atc90.pdf
I was right!
Cool ,thanks. Seams odd that you cannot run a high beam?? Wonder what would happen if I connected the high and low beam wires together?? I am assuming that I would have a bright light. Anyone do this?
