Oh boy, dont laugh fellas' as I am a newbie here.
I bought (actually traded for) my old 3 wheeler in a basket. I thought it was an 85' until tonight and I think it might be an 86'.
The Tri Z was in a serious accident in its past where a young kid was killed. The lower fork bracket and the wheel axle holder (sorry if my description is wrong) were broke and had to be re-welded to work. I am restoring this trike and am not comfortable running it this way.
Anyway, bought some forks of EBAY and a new lower bracket only to find that the forks that I bought (off of an 85'??) are smaller than what I have.
After reading and searching I learned that the 86's had 39mm forks as compared to 35mm on the 85's. This is why I now think my Tri is actually an 86.
I am new to this stuff and am wondering: Are the 86 forks and lower bracket going to be easy to find or should I just run the 85's? I am really torn here because I want it to be correct. However, I do not know enough to know if the 86 forks and bracket will be a real booger to find.
I am kind of glad because the 86's have the 6 speed. Are the 86's more desirable than the 85's? Is there anything else I can look for to determine if this is in fact an 86? Again, this thing is in pieces but I am determined!!!
Thanks fellas and sorry to be a little dense here!
to the boards. I know you want it to be correct, but the forks is something you don't want have doubts about. If your have an 86 Z and you need forks, chances are they will be very hard and expensive to find. You can use the ATC 250R front end and it will fit like a glove. This is the set up I have on mine, down to the 2 piston front caliper and 11" wheel. Honda
