I changed the clutch in my yamaha but when i put it gear nothing happens. i'm pretty sure its all put back together right, checked it a couple of times. is there anything i'm missing. Please help.
Did you adjust the clutch after installation according to the manual?
1985 Kawasaki Tecate 3
No i did not. where can i get a manual ? First time i have changed the clutch in my bike, maybe i should have done a little reading up on it first.
Sorry for the double post. I went and found the manual and it says....
1: Loosen the locknut and turn the adjustment screw counterclockwise until resistance is felt
2: Turn the adjuster 1/8 turn CLOCKwise then tighten the locknut while holding the adjuster nut.
Hope this helps.
Welcome to 3ww.
What year is your Yamahauler?
