Results 1 to 15 of 16
Thread: Cam Chain Adjustment:200X
    Nov 2009
    1,147
    Just was reading the service manual for the 200X and it says to start the engine, let it idle until warm. Then loosen the bolt for the cam chain adjuster. The way its worded it sounds like you leave the engine running, is that right. Or should you start it, let it warm up, shut it off, then adjust?
    not running,, but warm..
    Nov 2009
    1,147
    Thats what I thought but the way it was worded weird.
    Santa Barbara, California
    1,161
    You do leave it running....When I had my motor at my local honda dealer my mechanic told me how to adjust it and he said you do it while it's running.
    1985 Honda 200x
    Jonpin's Avatar
    Jonpin is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2008
    Melbourne Florida
    333
    I thought it was saying to have it running in the book to but also sounded wierd to me to.
    05 Kingquad 700 85 200x 85 250es 85 350x
    85 350x rider project 85 350x (project) watch the progress here http://3wheelerworldforums.com/showthread.php?t=85959
    Goin to prove you can polish a turd "so far it takes a lot of cash to buff that brown out'
    Monroe MI
    5,787
    From the 83-85 200x manual.
    1,161
    Thanks Mike, I've always adjusted my 200x's with it running and it works great. If you ever take the whole assembly apart in the bottom of the motor it'll make more sense.
    1985 Honda 200x
    Sep 2007
    100mi west of Chicago
    3,582
    Do it while running. If it is a noisy chain you will hear it get quieter as you adjust it and be quite proud of yourself.
    Rob
    Nov 2009
    1,147
    Thanks, I have a different manual than that. And it was real confusing cuz every street bike I have had you adjust it while it was shut off.
    85Tecate is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2009
    Iowa
    442
    Yes its adjusted at idle. (Engine running)
    1985 Kawasaki Tecate 3
    Monroe MI
    5,787
    Dec 2005
    Wisconsin
    1,141
    I adjust it while it's running. Sometimes I will take the nut/cover thing out and smack the center pin with a punch, the lock rings like to lock a little too well sometimes and not let the adjuster pin move like it should. A little force from a punch and a frees things right up.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    Nov 2009
    1,147
    You mean the little 10mm nut in the center and then use a punch in there?
    Dec 2005
    Wisconsin
    1,141
    Quote Originally Posted by 200XMichigan View Post
    Nope the big one that the little bolt goes into. Take it all the way out, it's almost like a threaded cap. Take the whole deal out and you will see the pin.
    1985 Honda 200x...
    ALL theses cam chains and guides are shot.....
    But, if you want to see how it all works, just take the left case cover off and you can see how it all works and either locks or free's itself...........
