Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 41
Thread: Fat Cat 250sx
    Dec 2007
    Quebec,Canada
    1,014
    Fat Cat 250sx
    Hi guy,here is the result of my work tonight!!! After 1:30 of work check it!!I was supposed to part out this rought 250sx with a bad axle but I finally give her a second life!probably the first one built,I have never see another one anywhere.The differential and the 2 swingarm part are from a suzuki gs650 1981,and I use the front of the SX swingarm.Can wait to take a ride!!!!
    Attached Thumbnails Attached Thumbnails FC250sx 001.jpg   FC250sx 002.jpg   FC250sx 003.jpg   FC250sx 004.jpg   FC250sx 005.jpg
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    Sep 2008
    845 New York
    2,302
    looks preety beast..what are you gunaa dofor fenders?
    1985 Quad Killer
    1985 Mini Raag
    1985 Green Gobbin X2!!
    1990 Kawasaki 300sx
    R.I.P
    Dec 2007
    Quebec,Canada
    1,014
    Front will probably be 250r,rear I don't know,I have a lot of motocross side panel and a nice seat with cutted rear fender
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Feb 2009
    michigan
    2,387
    that looks like fun when done.
    1985 ATC 250R
    . Team Red Trike
    OK
    5,450
    Is there a hole in the engine case where the shaft drive comes out of the trans/left side engine case?
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    Dec 2007
    Quebec,Canada
    1,014
    Yes it's a hole,the engine is supposed to be good but I will replace this part,I have a lot of them.Anyway I think the biggest challenge is the rear wheel setup!
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Jul 2006
    now thats some thought put into that!! a shaft drive missle!! wicked!
    Monroe MI
    5,787
    I believe that's a first, looking forward to more pics.
    Dec 2007
    Quebec,Canada
    1,014
    More Pics
    Some picture of the beast on the wheel.
    Attached Thumbnails Attached Thumbnails FC250sx 009.jpg   FC250sx 010.jpg   FC250sx 011.jpg   FC250sx 012.jpg   FC250sx 013.jpg   FC250sx 014.jpg
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    May 2009
    Fresno OH
    146
    hahaha that is way to cool well at least with the shaft drive you will not have to mess around with chain adjustment and the jackshafts!
    I do vinyl cutting on the side...lettering, decals, and window stickers or whatever you may want to put them on....ill cut anything dont be affriad to ask
    currently have: 85 atc250sx(200xfront conv)
    85 atc70 flat tracker x2
    86 atc250R
    85 atc250r
    79-85 atc110
    NICE BUILD!!
    I know you've got trikes and skillz but:
    Take that counter shaft out while the motor is on the side or thrust washers and parts get lost..... Many guys just pull the 3 bolts and thats the end for most
    Dec 2007
    Quebec,Canada
    1,014
    I know for the counter shaft removal,it's the previous owner that try to remove it It's the reason why I paid 50 for the whole bike
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Dec 2007
    Quebec,Canada
    1,014
    More picture!!
    Some picture of the beast,more of the plastic work is done,just have to finish and paint! Side cover are from a cr125 85 or 86....not sure.Plastic welded to the 250sx fender!
    Attached Thumbnails Attached Thumbnails at250sx 001.jpg   at250sx 002.jpg   at250sx 003.jpg   at250sx 005.jpg   at250sx 006.jpg   at250sx 011.jpg
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Nov 2009
    Canada
    135
    Wow very good work! Now you have a SUPER CAT!
    Let see us on video.
    1985- ATC 350X.................Stock (for now)
    1983- ATC 200...................W/250R Front end + 200X carb.
    1985- ATC 200s..................Stock (courtesy one)
    1983- ATC 200X..................For project!!!!
    1984- KXT 250 Tecate.........In project!!!!!!!
    1985- ATC 200m ................In project!!!!!!!
    'http://www.youtube.com/user/tordeur4x4'....on YOUTUBE to see all my videos!!
    Monroe MI
    5,787
