Results 1 to 8 of 8
Thread: ytm200 tranny not shifting . stuck in first
    PAPA250r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    greentown PA
    389
    i recently had to replace 5th gear on my ytm200. i put a used trans form ebay into the trike and it shifted by hand i made sure the trans and forks were installed right before i closed up the case.
    i put it back into the trike and it wont shift out of first gear and wont go into neutral either ?
    any ideas on what can be wrong ? could it be i didnt put something back together correctly in the right side clutch cover ? ? ?
    thanks for any help !
    Southern MN
    1,875
    Under the right side clutch cover could easily be the problem! Take it back off, and look at the shift machanism for a start. You will never know what it is until you rip back into it! Second time has to be the charm. Did you use a manual the first time you had it apart? I would have a manual as a reference and a guide to help you on your quest. Good luck!
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Monroe MI
    5,787
    ^X2, no way to know till you take it back apart and look.
    Nov 2002
    Kirkville, NY
    3,831
    Does the shifter move all he way up and down easily or does it move just a little bit then stop?
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    try tipping it on its side ,,wile jiggleing the shifter...Not completely on its side,, just as far as you can wile on the tire's. Try tipping it both ways,,
    and the pin has to be in the slot , under the clutch cover
    Feb 2009
    greentown PA
    389
    i did refer to a manual while i was doing the job. the shifter does move freely up and down and feels like its actually shifting but its not .
    Feb 2009
    greentown PA
    389
    would this happen is the primary clutch nut is too tight ?
    im gonna open up the right side case tuesday . hopefully problem in there..lol
    Nov 2002
    Kirkville, NY
    3,831
    Quote Originally Posted by PAPA250r View Post
    Sorry but no.
    Check the shift arm behind the clutch, thats what it sounds like to me.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
