Results 1 to 7 of 7
Thread: Need help with removal of clutch
    muddog's Avatar
    muddog is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2009
    Manitoba
    225
    Question Need help with removal of clutch
    i need help removing a manual clutch from a '86 250ES the lock nut wont budge. Does any body know a good solution to this?
    (sorry about the dubbel post don't know what happened with the other one)
    Using a manual isn't that like cheatin?
    There ain't quite nothing like the smell of diesel fuel in the morning!
    OK
    5,450
    A manual clutch on a 250ES? I didn't know they had a manual clutch? Have you tried using an impact on it?
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    Monroe MI
    5,787
    muddog's Avatar
    Dec 2009
    Manitoba
    225
    i cant get my socket on the nut.
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by muddog View Post
    Proper tools work wonders. Try getting a socket that does fit the nut.
    Howdy
    They have a manual clutch and a centrifical clutch....
    I can't see what the issue is?? Wrong socket? Too fat walled and doesn't fit in there?? or?????????????
    Sometimes they have backwards threads on one or the other, a MANUAL would tell you that and the size socket to use in some cases.
    Otherwise you risk ruining some parts, but thats what most guys have been doing for years so join the club.
    muddog's Avatar
    Dec 2009
    Manitoba
    225
    the socket end is tapered so it would barely grab the nut and slip, i used a cold chisel and (welcome to the farmers world a does everything) i got it off though
