Results 1 to 12 of 12
Thread: 200s running problem
    waukesha Wisonsin
    43
    i have a choke related problem(i belive) it runs fine on full and half chocke but as soon as i turn it to no choke it dies. if i turn it to no choke while riding it will drive fine till i let of the gas then it bogs out and kills. it smells like it is running verry rich. i was wondering if i could get an answer of wht i should adjust the jets to. (there not dirty i just tor it down and cleand all parts.)what is a good adjust ment to start with if this is evean the problem. please help!!!!!!
    ilmoakw is offline At The Back Of The Pack Arm chair racerFirst time rider
    moncton
    244
    ***edit*** Im a moron LOL>
    Nov 2008
    ontario
    1,055
    yes like stated clean it its most likely plugged pilot jet, its running rich because the choke makes it run extremly rich its also hard on the motor to run with the choke on because the gas washes the oil off the rings
    proud owner of a trx300ex quad and an 85 atc 70
    waukesha Wisonsin
    43
    i cleand the pilot jet i can see threw all holes i also soaked in carb clean for 15 min. then took a wire out of a twisti tie and cleand it outt.??? is ther any outher problem . like could it be the adjustment of the carb?? becuse i no i did not adjust the jets right but it was doing this befor i did any thing to the carb
    Nov 2008
    ontario
    1,055
    could be your fuel mixture screw located in front of the carb bowl, also the idle screw could just be set too low
    Nov 2008
    ontario
    1,055
    mixture screw should be lightly bottomed out then 1 7/8 turns out then set the idle
    waukesha Wisonsin
    43
    i will try that thanks much!!
    Apr 2007
    UP of MI
    804
    If I were you, I would've just put a kit with new jets into it. They're under $20 so you know you've got the right size jets and that they haven't been "cleaned" repeatedly to make them bigger. It can't hurt to try the advice above though.
    1973 Honda CB350
    1973 Honda ATC70
    1978 Honda ATC90 (FOR SALE!)
    1982 Honda ATC110 (FOR SALE!)
    1982 Honda ATC200
    1983 Honda ATC200E
    2002 Honda Recon
    Monroe MI
    5,787
    From the 200s shop manual.
    Feb 2009
    michigan
    2,387
    make sure all your settings are factory and your float didnt get readjusted by mistake.
    1985 ATC 250R
    . Team Red Trike
    Nov 2009
    Okauchee, WI
    555
    Quote Originally Posted by daniel_250r View Post
    I have my '83 ATC200 set like this and it runs pretty good. I haven't moved the clip on the needle though, don't know where it's set at.
    '85 Honda 200X
    '85 Honda Big Red 250es
    '85 Honda 250R
    '82 Honda ATC 70
    '87 LT500R Quadzilla
    BRUP!!!!!!!!
    Nov 2009
    Canada
    135
    Thanks MonroeMike for the info,...it will be useful!
    My next question as answered by Mtsnieg,....Cause i bought a Atc200 83 yesterday!!
    1985- ATC 350X.................Stock (for now)
    1983- ATC 200...................W/250R Front end + 200X carb.
    1985- ATC 200s..................Stock (courtesy one)
    1983- ATC 200X..................For project!!!!
    1984- KXT 250 Tecate.........In project!!!!!!!
    1985- ATC 200m ................In project!!!!!!!
    'http://www.youtube.com/user/tordeur4x4'....on YOUTUBE to see all my videos!!
