saw this on the ebay forum, couldnt pass this up. $75!!!
after cleaning the carb, which was gummed up, fires and idles on first pull.
great compression. 1985 model
needs, 3 new tires , dry rotted, front fender, gas cap. cracked from being overtightened, and strip the spray paint off the un cracked plastic.
going to port the cylinder , remove the oil pump and all those heavy gears, shave the head, and add different clutch weights.
