Results 1 to 15 of 27
Thread: Looky my new $50 trike!
    New Brunswick, Canada
    26
    Hey folks. Thanks already and in advance for all the help I'm gonna get from you folks
    Just picked up this '83 ATC185 from my co-worker for the goodly sum of $50. Needs a front tire and carb work, plus other misc cleanup.. but it's pretty much all there!
    Carb was CAKED full of crud, but after giving it a boil cleaning, it looks quite nice.. all the passages cleaned up nicely. Only problem I have with carb now is fuel leaks out the drain / overflow hole.... I initially thought it was overflowing and the float needle wasn't sealing, but if that was the case then once I shut off the petcock the flow of gas out of the carb shoulda stopped! So now wondering if the drain screw isn't sealing/seating right. Thoughts on that guys?
    But the good news is she pulls over nice and obviously catches/runs for a few sec.... will tune it up once I have it NOT spewing gas all over the engine.
    The front tire's never gonna hold air again.. but do you think I can simply put a tube in there?
    Some pics..
    Should be loads of fun!
    Getmoresoon!!
    Apr 2009
    north tonawanda ,new york
    133
    sweet find for 50bucks. i have one my self its a blast to ride welcome to the bords
    Feb 2009
    michigan
    2,387
    if gas comes out even with petcock closed the petcock is malfunctioning.over flow is two things,incorect float level or stuck float pin.clean her up again and double check all settings to the manual
    1985 ATC 250R
    . Team Red Trike
    Monroe MI
    5,787
    Dec 2009
    the ville illinois
    477
    a little work and youll have yourself a nice ride.
    Southern MN
    1,875
    You could deffinatly put a tube in that front tire, if its not dry-rotted to the point you could fit your hand in there. I guess you could also try some green slime if its just small cracks. Nice steal for $50! Best deal I got on a 83' 185 was $60, but it had incorrect forks, solid and bent, and I had to replace the coil and clean the carb. Nice project!!!
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Dec 2002
    374
    not bad at all
    UlsterATCFan's Avatar
    UlsterATCFan is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2008
    UK
    363
    That trike looks fairly complete and original, best $50 you ever spent
    Sep 2007
    100mi west of Chicago
    3,582
    I believe the 185s has the metal tab in the carb that you can bend so the float pushes the valve up higher to stop the flow of gas. I have had to do this on several trikes. If the little tab is plastic this trick won't work.
    Rob
    juggaloclownz18's Avatar
    juggaloclownz18 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    The woods of 315 - NY
    303
    Ive got the same problem with my 200s that i just cleaned the carb on, except the petcock stops it when i turn it off..... The float and needle looked good when i cleaned the carb too, now im disappointed, I really wanted to ride my new buy..... Oh well i guess thats the steps i need to go through with a barn find that sat there for over 10 years at least i figure..... Good luck, check your petcock/fuel strainer would be my uneducated guess....
    85 ATC250r (been waiting way too long!!)
    Tusk Hand Guards
    DG full exhaust (want different one)
    TAG handlebars
    +4 LSR axcaliber axle, carrier, hubs
    FMF Carbon Fiber reeds,
    K&N Filter/air box lid removed
    Motion Pro Twist Throttle
    Pro Armor Tether switch
    Seal Savers - long version
    23" Dirt Devil front - 22" holeshots back
    Soon to be ported/polished (got the work setup on trade)
    26
    So parts hunting now.. is there anything I should be wary of? Found this post from a guy nearby... I'm struggling with the thought of paying $100 for parts from this guy when I bought the bike for $50
    "I HAVE A BUNCH OF SPARE PARTS FOR MY 200E. THE PARTS I HAVE WILL FIT ON ANY 185 OR 200 HONDA THREE WHEELER. I HAVE FULL MUFFLER TWO GOOD CARBS CYLINDER CAM VAVLES TWO TIMING CHAINS SEAT TANK TWO COMPLETE HEADS IN GOOD SHAPE AND A FEW OTHER ODDS AND ENDS"
    Do most/all 185/200 parts between the years interchange relatively nicely? I noticed that the carbs changed over the years.. and settings / jets between the 185 and 200 vary a bit. The other parts should generally fit I think.. only bore size on the cyl head seems diff in the specs? Totally ignoring bottom end which has obvious differences.
    Getmoresoon
    Hampton, Virginia, C.S.A.
    2,664
    the 50 dollar finds never get old...i found a 84 200s one time for $50 took it home and was riding it within a hour hehe
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    Feb 2008
    Orange County California
    726
    Wow! Your soooooo lucky! I am jealous!!!!!!!!!!!!!!! Seriously!!!!!!!!!!!!!!!!!!!!!
    1986 ATC250r
    1984 ATC70
    May 2007
    Orange County, NY !
    1,673
    I get all teary eyed when another trike gets rescued, good job!
    26
    Picked up a tube for the front today.. that was a bit of a challenge in this area. Only *1* of the 4 cycle places here had a tube to fit (or tire for that matter!). So, silly me figured I'd break the bead, pop in the tube air up and be done tonight.
    Yeeeah.. riiiight!
    Damn, that's a tough bead to break. Certainly wasn't happening by hand (ok, so the only other tire I cracked off was a Utility trailer tire.. who knew ) so a quick bit of googling and we have the Redneck method of bead breaking... 2x4 and drive up on it. Yeah, well, now I have 2 nice pieces of 2x4, and the bead's still set
    Guess I give in and pay the garage down the road to do the tire for me tomorrow after work.
    Fun times!
    Getmoresoon
