Results 1 to 15 of 18
Thread: new tecate t-3 in my fleet
    Nov 2005
    New Jersey
    659
    Picked this up during the week, tell me what you think.I plan on stripping it down and going over it in the spring time.It is all complete-let me know of you see anything rare, wrong, or a part thats not right please as I have not owned a tecate since the late 80's.Here's a link to the pictures: http://s733.photobucket.com/albums/w...r/Tecate%20T3/ It has some issues, leaking carb,killswitch nightmare,gaurds missing,alot of little stuff.I havent had the time to really dig into it, will start that process this week hopefully.Any info you guys can give me on this is greatly appreciated.Tell me what you think.
    http://www.pilotodyssey.com/PO/index.php
    88 TRX LRD,39MM pwk,Durablue+4.Nice rider
    85 250r West Coast +4,Durablue +4,Boyesen rad valve,Keihin 39mm,Rad double row carrier
    86 250R west coast +4,Durablue+4,Maier plasitcs, Keihin, Boyesen,Wiseco big bore kit
    85 350x-all new everthing,trailer queen,all OEM-NOT FOR SALE!!
    4-FL400R HONDA PILOTS.See my section on the page!
    2-85 T-3 Tecates all the bells and whistles
    85 T-3 project trike in works
    OK
    5,450
    It looks like a really good start. Keep us updated on the redo. It looks totally stock except for the silencer, which looks like a DG.
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    Nov 2005
    New Jersey
    659
    It is a DG, BUT IT appears it is mounted backwards as the DG logo is facing inside and one of the mounts isn't near a mount on the frame.Also,the previous owner must have run the mixture way high as the complete exhaust is coated with oil, needs a good run to burn it out for sure.The expansion chamber looks stock correct?Rear sprocket is a 42 thats stock as well?
    Bartlett TN
    3,083
    Looks like a nice tecate! Seems like more and more are adding these sexy babes to their fleet.
    86-87 Tecate ROCK!
    Monroe MI
    5,787
    Nov 2005
    New Jersey
    659
    Wheres a good place to look for parts for this?Is there a member here that sells them?I need a kill siwtch and rear carrier seals/bearings immed for it to start riding it to CSI the motor and trike more.
    Aug 2009
    Newfoundland, Canada
    915
    someone used silicone to seal the expansion chamber to the motor or are you supposed to do this on two strokes?
    Apr 2002
    s.w. michigan
    6,498
    Geese, looks like you should just ride it now ! Nice machine.
    The only 2 things that stand out for me to advise on (I did not look close up on all pictures) is to get a front chain guard and the radiator hose clamp on the carb to intake boot is a no no. It will cut right into the bottom area of the intake boot if it has not already done so.
    Yep, lots of Kawi talk recently john
    Feb 2009
    michigan
    2,387
    nice t3,congrats on the pic up.
    1985 ATC 250R
    . Team Red Trike
    OK
    5,450
    Get your bearings from www.goallballs.com
    Here is a kill switch
    http://cgi.ebay.com/ebaymotors/KAWAS...item5d25d76abb
    Rides:
    My feedback thread
    Nov 2005
    New Jersey
    659
    Thanks for the ebay link ! Do they still sell the front chain guard?
    OK
    5,450
    Quote Originally Posted by mudbogger View Post
    Yes, $15.66 at bikebandit
    http://www.bikebandit.com/houseofmot...m4335sch425952
    Rides:
    My feedback thread
    Sep 2005
    MICHIGAN
    2,027
    I used high temp gasket maker on my exhaust and it worked good combined with proper gaskets.
    I do not believe the chain guard is available even though many sites like bikebandit will list them. You can use one off nearly any KX250.
    You might want to look at my thread here and add to it if you find some things to fit:
    http://www.3wheelerworld.com/showthr...ap-Interchange
    86 T3
    84 T3
    86 KX250
    Nov 2005
    New Jersey
    659
    Quote Originally Posted by nd4speed View Post
    wow, what a thread!!!! tha'ts got so much information, I couldn't take it all in, but it is bookmarked!!!I bought the rear carrier bearings and the kill switch, now I will go on and look into the rear shock,motor, air filter, and do a CSI on what I'll need next here on it.
    eyecekold1's Avatar
    eyecekold1 is offline Check my feedback before buying from me First time rider
    Oct 2009
    Provo Utah
    209
    Whats up with the shock? Did you want a new one or just options on what will fit in its place? I know a Yamaha Raptor shock fits but, it gets mounted upside down. BTW nice find I love my tecates
    85 350x 12:1 piston and porting by "boosted96cobra"
    4 85 tecates 1 runs
    5 84 tecates none run
    1 84 Yamaha Zinger, mildly ported & polished, milled, bored .25 over finally running
    2 atc 90's just parts bikes
    00 rm250
    93 kx500
    2 Honda 200m parts bikes
