how do you adjust the timing chain on a 200s ??????????
Check the manual.
http://72.52.143.80/~trikes/Manuals/...p%20Manual.pdf
just make sure the locknut is tight. i forgot that and had a rattly 185S.
You will cry, you will scream if you've heard half the **** I've seen.
Are you gonna get up and burn an X in your head?
"Cut throught the bone and cut through the wire"
Trikes:
84&85 Tecates
85 R
85 X
Support Scrapthraher Customs!!! Home of the Three Wheel Outlaws! PM me if you need a head rebuilt, valves cut, head milled or lapped!!!!!
