Thread: ytm200 clutch help !
    PAPA250r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    greentown PA
    389
    having trouble with my ytm200 . I recently changed my bottom end and had swap out everything in the right side cover.
    anyway I installed the motor it started right up . I shifted through the gears everything worked good on blocks . then it stopped . I shifted into the gears and nothing hapened . wheels turned slightly but stopped at soon as I let it off the blocks .
    what would cause this ? secondary clutch too tight ? to loose ? primary clutch too tight too loose ??
    thanks for any help
    Feb 2009
    greentown PA
    389
    any ideas ? also the 'increase-decrease' adjustment screw is bottomed out and does nothing ?
    Monroe MI
    5,787
    Try adjusting the clutch.
    Loosen the locknut. Turn the clutch adjuster with a screwdriver counter clockwise until resistance is felt. Turn it back, 1/8 turn (clockwise). Tighten the locknut to 11 ft.-lbs.
    Feb 2009
    greentown PA
    389
    thanks I just seeen that . I have a haynes manual but its not as detailed as the honda manual. and I can't view pdf files right now.
    ill give that a shot .
    Feb 2009
    greentown PA
    389
    took it back apart and i didnt have the arrows lined up on the clutch . and it kept it form tightening right..lol
    running great now . thanks for the help
    Monroe MI
    5,787
