Results 1 to 15 of 24
Thread: 1982 Honda ATC185s Wont stay running!
    Monroe, Michigan
    23
    Just picked up a 1982 Honda ATC185s last night for 300 bucks, guy started it RIGHT up with one pull, I drove it through my neighborhood for about 10 mins, then back. Ran great, shifted great, GREAT WOT response.
    Later on, drove it to the next neighborhood, 2 miles down the road, ran great, shut it off for 10 minutes at my gf's. Started it, drove around for about 5 minutes and noticed it popped a few times when i slowed down to turn; hen it stalled, (I let off the throttle all the way)
    It took about 10 pulls to restart it, drove it 1000 feet, and stalled AS i was driving, about half throttle. WOULD NOT START to save my life for about 5 mins.
    Now when it does it, I gotta wait 5 mins or so, then starts right up, and drives about a 3rd of a mile before it dies. No matter how much throttle I try to save it with its already decided its dying.
    I talked to my uncle, he said check the spark plug, CDI box, and drain the carb with the screw at the bottom, and run a half tank of premium through it.
    Anyone else have this problem before?
    Heres a pic of it btw:
    Its also taken me over 25 minutes to post this thread...I hope this sites not always so laggy lol!
    muddog's Avatar
    muddog is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2009
    Manitoba
    225
    dont bother with the premium the only difference between premium and regular is octane level (knock resistance) that wont make a difference unless you are running high comp.
    Using a manual isn't that like cheatin?
    There ain't quite nothing like the smell of diesel fuel in the morning!
    Monroe MI
    5,787
    Monroe, Michigan
    23
    Yea, the vents in the "ON" position, fuel lines on, how does the choke work...(What is open and what is choked?) It seems to only start with the choke all the way up, and runs like oo with it in any other position
    Your in Monroe too? Sweet...Im out in Brest Bay.
    Monroe MI
    5,787
    Monroe, Michigan
    23
    Okay, im assuming its gotta be carb issues, as it will only run fully choked....
    I just sat here and read that whole manual haha.
    I would like to install the "DC Kit" as they called it, Cant I just mount a battery, and find the +, - for the headlight and wire it into that? I would like to install a brigher setup on there, along with an LED taillight...
    Monroe MI
    5,787
    UlsterATCFan's Avatar
    UlsterATCFan is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2008
    UK
    363
    Before you start tearing into it make sure theres PLENTY of petrol in the tank and the fuel lines are unblocked. The fact that it was running OK when you got it points to something simple
    Feb 2009
    michigan
    2,387
    i'd check fuel flow also.is the tank rusty?
    1985 ATC 250R
    . Team Red Trike
    Monroe, Michigan
    23
    Nope, no rusty tank; I dont believe theres any clogs, but thats all a possibility, Ill check all the basics today when I get home from school later.
    The thing though, for who said it ran fine when I first rode it...it was cold, and I only rode it for a little over 5 minutes, and when its cold I can usually ride for about 10 to 15 minutes before it starts doing it
    Nov 2009
    Missouri
    87
    The tank vent's can plug up, have you tried just taking the cap off the tank when it quits to hear if it's sucking in any air?
    1999 Kawasaki Bayou 220
    1980 Honda ATC110 (Work in Progress)
    hoser's Avatar
    hoser is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2005
    ILLINOIS
    284
    Ok you just bought it time to go through the entire fuel system and leave nothing unchecked.
    Sounds like your running out of gas if you wait a few min then it will run again, could be the path from the tank to the carb is restricted, to avoid future problems as I suggested above now is the time to go through the entire fuel system.
    Dont blame the CDI in 35+ years of wrenching on ATV's only seen one CDI go bad and it had been modified and not sealed up properly so moisture got into the board, all intermittent spark problems I have found was from a bad connection not bad components.
    Apr 2007
    UP of MI
    804
    The first thing I ever do when I get a new bike is rebuild the carb. Kits are under $20 shipped.
    1973 Honda CB350
    1973 Honda ATC70
    1978 Honda ATC90 (FOR SALE!)
    1982 Honda ATC110 (FOR SALE!)
    1982 Honda ATC200
    1983 Honda ATC200E
    2002 Honda Recon
    Dec 2009
    the ville illinois
    477
    as soon as it dies again, open the carb bowl drain and see if any fuel comes out.There should be a screw in the side of the bowl or a plug in the bottom.
    Sep 2007
    100mi west of Chicago
    3,582
    FYI you have an 83 185s!
    Rob
