Hi, new to the forum and also to atc's. Just picked up a nice 86 200s off craigslist for $250 it didn't run and the guy said it needed a carb clean. I got it home and started messing with it. I cleaned the petcock took the carb apart cleaned it out. Changed the plug and oil. I got it started on the second pull, but idled too high so I adjusted that. If you give it any more gas than 1/8 throttle it will bog and die! With the choke on you can give it maybe 1/4 throttle but when its warm and choke off only 1/8. It does idle good and doesn't die if you just let it idle
Any ideas??
