Results 1 to 9 of 9
Thread: 200x problems
    Wisconsin
    8
    200x problems
    I have 83 honda atc 200x that I have a hard time getting to run. I have good spark and fuel. It runs great when I can get it to kick over but it takes me about 15 minutes to get it to start. Does anyone have any ideas on what I could do to solve this problem? I really like this trike and would like to keep it for awile. please help
    Feb 2009
    Rome,NY
    1,046
    sounds like a dirty carb ... have you cleaned it or better yet got a kit for it?
    Wisconsin
    8
    I have cleaned it. no difference would a carb rebuild kit fix the problem?
    Monroe MI
    5,787
    big yeller's Avatar
    big yeller is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2009
    southeast texas
    247
    agreed adjust the valves...had the same problem on my kawasaki bayou.
    1984 yamaha 200k
    1985 honda 70...some times swap the 125 lifan for fun
    1984 honda 200es
    1985 honda 200x
    atvs:
    2013 Honda Rancher 420 ES
    Dec 2009
    Springfield, Missouri
    527
    I had an 87 250x quad that was doing the same thing to me. It had good spark and a clean carb, but would not fire. By chance I changed the spark plug and it started every kick and ran great. Sounds way too easy, but i would rule that out definately before i ripped the cover off and started adjusting the valves.
    Jun 2009
    Tunkhannock,Pa
    904
    yeah throw a new plug in it
    1985 200X
    66mm H&S Piston
    Little Bit Bigger Cam
    Bassani Exhaust
    1985 350X With Bassani Exhaust
    1983 Honda 200E (PARTING OUT!!!!)
    1985 Yamaha Tri-Zinger
    My Feedback Threadhttp://http://www.3wheelerworld.com/showthread.php?105185-Feedback-for-RodKnockRacing&highlight=RodKnockRacing
    Wisconsin
    8
    k thanks will try
    Nov 2009
    1,147
    Mine had a leak around the exhaust gasket, starts a lot better now that it had enough back pressure. Also could be a leak on the carb side.
